changeip
Decimals ?
Wed Jun 11, 2008 9:21 pm
Doesn't MT support decimal places ??
[admin@MikroTik] interface> :put (5 / 2)
2
Since when did 5 / 2 = 2 ?
I'm trying to parse the GPS coordinates and convert them back to decimal. Here is a sample script but I cannot get any further since the math is broken.
:global gps [/system gps monitor as-value]
:put ($gps -> "date-and-time")
:put ($gps -> "longitude")
# Parse Longitude
:global long1 [:find ($gps -> "longitude") " " 0]
:global long2 [:find ($gps -> "longitude") " " $long1]
:global long3 [:find ($gps -> "longitude") "'" $long2]
:global long4 [:find ($gps -> "longitude") "''" $long3]
:global degrees [:tonum [:pick ($gps -> "longitude") $long1 $long2 ] ]
:global minutes [:tonum [:pick ($gps -> "longitude") $long2 $long3 ] ]
:global seconds [:tonum [:pick ($gps -> "longitude") ($long3 + 2) $long4 ] ]
:env print
# Should give decimal longitude.
:put ($degrees + ($minutes/60) + ($seconds/3600))
I end up with this:
"gps"={"date-and-time"="jun/11/2008 18:19:25"; "longitude"="W 117 12' 55''"; "latitude"="N 33 13' 49''"; "altitude"="191.399994m"; "speed"="0.111120 km/h"; "valid"=true}
"long1"=1
"long2"=5
"long3"=8
"long4"=12
"degrees"=117
"minutes"=12
"seconds"=55
[master@cip-home] /system gps> :put ($degrees + ($minutes/60) + ($seconds/3600))
117
What happened to my decimals!
If I can get this working I have a script that will upload your routers GPS location to GpsGate.com servers and so you can keep track of your whereabouts on all gps-enabled routers.
Sam
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
mrz
Re: Decimals ?
Wed Jun 11, 2008 11:07 pm
Math is not broken. Router os support only integers.
dssmiktik
Forum Veteran
Forum Veteran
Re: Decimals ?
Wed Jul 22, 2009 1:06 am
This will calculate exact decimal values to any decimal places you want. Just plug in dividend, divisor, and decimal places and $result variable will be set to the answer.
# Preforms calculation with decimal points
# dividend / divisor = quotient.decimal = result
:local dividend 3
:local divisor 11
:local decimalplaces 3
# Math Calculation here
:local quotient 0
:local remainder 0
:local result 0
:local decimal 0
:set quotient ($dividend / $divisor)
:if ($quotient = 0) do={
  :set dividend [:tonum ($dividend . "0")]
:set remainder ($dividend - ($divisor * $quotient))
:if ($remainder > 0) do={
  :local tmpremainder [:tonum ($remainder . "0")]
  :for x from=1 to=$decimalplaces do={
    :local tmpdecimal [:tonum ($tmpremainder / $divisor)]
    :set decimal [:tonum ($decimal . $tmpdecimal)]
    :set tmpremainder [:tonum (($tmpremainder - ($tmpdecimal * $divisor)) . "0")]
  :set result ($quotient . "." . $decimal)
} else={
  :set result $quotient
# END Math Calculation here
:put ($dividend . " / " . $divisor . " = " . $result)
Hope this helps.
Doug
Jotne
Re: Decimals ?
Fri Aug 30, 2019 6:17 pm
2019 Is this still true?
local speed 10
:put $speed
:local speedknots ($speed * 5)
:put $speedknots
10
50
local speed 10
:put $speed
:local speedknots ($speed * 1.5)
:put $speedknots
10
Script Error: cannot multiply time interval by ip prefix
local speed 10
:put $speed
:local speedknots ($speed * 1,5)
:put $speedknots
10
10;5
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
mrz
Re: Decimals ?
Mon Sep 02, 2019 10:55 am
Yes only integers. Anywhere where you see decimal representation is actually a string.
Jotne
Re: Decimals ?
Mon Sep 02, 2019 7:43 pm
I know, but MT could add BC or other Linux tool to the script to handle decimal.
Lokking forward to v 7.0 :)
MikroTik->Splunk
Users browsing this forum: No registered users and 7 guests
