ajmal
MRTG Grapher
Thu Mar 24, 2005 6:37 am
Hi All
How to configure MRTG grapher for bandwidth Ussage in MT router for indivisual IPs.Is it possible if please give me with an example.
regards
edzix
Thu Mar 24, 2005 10:40 am
in MT you just have to enable SNMP service:
http://www.mikrotik.com/docs/ros/2.8/root/snmp
Edgars
GJS
Fri Mar 25, 2005 8:32 pm
...then use "print oid" in the relevant submenu to get the OID of the parameter you want, bytes-in, bytes-outin your case, then paste these OIDs into your MRTG config file. You can only get OIDs for these items:
/interface
/interface pc
/interface wavelan
/interface wireless
/interface wireless registration-table
/queue simple
/queue tree
/system identity
/system resource
Hope that helps.
Guy
wispuk.org
A Forum Community for UK WISPs
sergejs
Sun Apr 03, 2005 12:54 am
than put IP to Simple Quee, which you need to monitor.
than /queue simple print (needed) OID
and put it to mrtg config file :D
Good Luck.
Users browsing this forum: No registered users and 23 guests
