MUM Europe 2020
heiko_s
emailing a list - or writing to a file
Sun Jul 06, 2008 11:35 pm
Hi folks,
i'd like to create a daily email to my account which contains a list like this:
User: xyz download 12345 MB - Upload 345 MB
User: zxy download 54321 MB - Upload 543 MB
... and so on for all 350 users in my usermanager.
I'v already implemented the search for the useres and amounts - thanks to the automated billing script - but i've found no possibility to write to a file or create a list in memory which i can email.
Has anyone an idea how to create a file to email or can tell me how to fill a list variable in a foreach loop?
Many thanks in advance!
Regards Heiko
heiko_s
Re: emailing a list - or writing to a file
Tue Jul 08, 2008 2:29 pm
No solution in sight ? :?
mrz
Tue Jul 08, 2008 2:40 pm
You can store anything you want to send in a variable and at the end of script just do
/tool e-mail send body=$myVar
heiko_s
Tue Jul 08, 2008 10:58 pm
i figured that out, but i'm wandering what limitations the variables have... :?
omega-00
Sun Jul 27, 2008 10:56 am
heiko_s I've been working on something similar to what you want, without requiring the usermanager.
Its still a work in progress but what I have now works ok for what I want.
Feel free to rewrite any parts of the emailing section for your own use.
I've been trying to add it into a wiki page but the wiki wont' work for me at the moment.
Main changes from the Automated billing system is that my code doesn't require a set field length, just uses special chars (in this case ! and #) to identify the seperate sections.
=====WIKI=====
==Summary==
I wrote a usage tracking script based on the original Automated Billing Script
The way I run it is using a Mikrotik box setup to pass everything through transparently then I generated a Queue per IP address to keep track of the usage. On my test box (A PowerRouter 732) I currently have 3 class C blocks passing through with only 3% cpu (Multi CPU enabled).
==Todo==
I plan on giving this script the ability to backup to a file on the mikrotik so it will count both data in the queue currently + data usage saved in the file (in case you lose power to the device or have to restart it at any time)
I also plan on modifying the monthend script further so that it can only be triggered on the last hour of the last day of the month. This means you could then run the usage script hourly to get more frequent updates.
See below the script for details on how it works.
=The Scripts=
==Overseer==
Like the automated billing, this also has a calling script "Overseer"
 :global found
 /system script run monthend
 :if ([$found] = "true") do={ /system script run monthlyreport; :log info "--Completed Monthly Report--"}
 :if ([$found] = "false") do={ /system script run usagewarning; :log info "--Completed Usage Report--"}
==Monthend==
If it is the end of the month, the Monthly report must be run and counters reset, rather than the usage report.
This finds our if it is end of month or not.
 :local date
 :local time
 :local day
 :local month
 :local year
 :local hour
 :local minute
 :local yeardiv
 :local yearmult
 :local leapyear
 :local lastday "0"
 :global found ""
 :set date [/system clock get date]
 :set time [/system clock get time]
 :set month [:pick $date 0 3]
 :set day [:pick $date 4 6]
 :set year [:pick $date 7 11]
 :set hour [:pick $time 0 2]
 :set minute [:pick $time 3 5]
 :set yeardiv ($year / 4)
 :set yearmult ($yeardiv * 4)
 :if ([$yearmult] = $year) do={ :set leapyear true } else={ :set leapyear false }
 :if ([$month] = "jan") do={ :set lastday "31" }
 :if ([$month] = "feb") do={
        :if ($leapyear = true) do={ :set lastday 29 }
        :if ($leapyear = false) do={ :set lastday 28 } }
 :if ([$month] = "mar") do={ :set lastday 31 }
 :if ([$month] = "apr") do={ :set lastday 30 }
 :if ([$month] = "may") do={ :set lastday 31 }
 :if ([$month] = "jun") do={ :set lastday 30 }
 :if ([$month] = "jul") do={ :set lastday 31 }
 :if ([$month] = "aug") do={ :set lastday 31 }
 :if ([$month] = "sep") do={ :set lastday 30 }
 :if ([$month] = "oct") do={ :set lastday 31 }
 :if ([$month] = "nov") do={ :set lastday 30 }
 :if ([$month] = "dec") do={ :set lastday 31 }
 :if ([$lastday] = $day) do={ :set found true } else={ :set found false }
==Usage Report==
The main usage report, takes the name of each queue and looks firstly for a hint that any data is contained in this.
I have used ! to seperate the initial data block so If it finds a ! it will treat this name as data.
The data is then broken up from a name like this:
Any Site name!50#info@yourcompany.com!00
this then gives us $sitename (descriptive name) $gigs (gigabyte download limit) $email (address to email report to) $lastwarning (previous usage warning level)
If you just name a script without any ! in it, this will be ignored in the processing (useful for naming devices without reporting)
 :local content
 :local i
 :local sitename
 :local gigs
 :local email
 :local megstotal
 :local totalcurrent
 :local bytesdowncurrent
 :local bytesupcurrent
 :local megsdowncurrent
 :local megsupcurrent
 :local percentage
 :local lastwarning
 :local warninglevel
 :local warn
 :local update
 :local newwarning
 #Script based on Automated billing script at http://wiki.mikrotik.com/wiki/AutomatedBilling
 #Details:
 #This script checks all current simple queues and using values stored in the queue name will allow you keep track of usage by each site
 #The details stored in the queue are broken down and used to determine if a user should also be sent an usage warning at 50 75 90 and 100%
 #You can create/modify a new entry as long as you follow this format
 #1) If you just want to name an entry you may do so like "XYZ Router" in the queue name
 #2) If you want to determine a data limit, enter it like "sitename!gigabytelimit#emailaddress!00"
 #Breaking it down, sitename is.. a descriptive name, gigabyte limit is the monthy limit, email address is the address you want notified, 00  is the last warning level-set this to 00 when creating a new site.
 # This version created by Andrew Cox - www.accessplus.com.au
 :log info "------ Begining Daily Usage Reports -------"
 #For each queue in the list
 :foreach i in=[/queue simple find name !=""] do={
 #Pull name out of queue and divide up accordingly
 :set content [/queue simple get $i name]
 #Determine variables from name
 #Format is: sitename ! gigsallowed # who-to-email ! last warning level(0-50-75-90-100)
 :if ([:find $content "!"] != "") do={
    :local pos1 [:find $content "!"]
    :local pos4 [:len $content]
    :local pos2 ([:find [:pick $content ($pos1+1) $pos4] "#"]+$pos1+1)
    :local pos3 ([:find [:pick $content ($pos2+1) $pos4] "!"]+$pos2)
    :set sitename [:pick $content 0 ($pos1)]
    :set gigs [:pick $content ($pos1+1) $pos2]
    :set email [:pick $content ($pos2+1) ($pos3+1)]
    :set totalcurrent [/queue simple get $i bytes]
    :set lastwarning [:pick $content ($pos3+2) $pos4]
    :local pos5 [:find $totalcurrent "/"]
    :local pos6 [:len $totalcurrent]
    :set bytesupcurrent ([:pick $totalcurrent 0 ($pos5)])
    :set bytesdowncurrent ([:pick $totalcurrent ($pos5+1) $pos6])
    :set megsupcurrent ($bytesupcurrent / 1048576)
    :set megsdowncurrent ($bytesdowncurrent / 1048576)
 #Begin calculating usage percentage
    :set percentage (($bytesdowncurrent * 100) / ($gigs * 1073741824))
    :log info "$sitename: $percentage%"
    :if ([$percentage] < 50) do={ :set warninglevel "00" }
    :if ([$percentage] > 10) do={
      :if ([$percentage] < 75) do={ :set warninglevel "10" }
      :if ([$percentage] > 75) do={ :set warninglevel "75" }
      :if ([$percentage] < 90) do={ :set warninglevel "75" }
      :if ([$percentage] > 90) do={ :set warninglevel "90" }
      :if ([$percentage] < 100) do={ :set warninglevel "90" }
      :if ([$percentage] > 100) do={ :set warninglevel "99" }
 # Parse warning necessity
   :if ([$warninglevel] > $lastwarning) do={ :set warn "true" ; :set update "true" }
   :if ([$warninglevel] = $lastwarning) do={ :set warn "false" ; :set update "false" }
   :if ([$warninglevel] < $lastwarning) do={ :set warn "false" ; :set update "true" }
 #Update Warning Levels
   :if ([$update] = true) do={ :set newwarning $warninglevel } else={ :set newwarning $lastwarning }
   :if ([$warn] = true) do={
   /tool e-mail send to=$email from=something@somewhere.com server=1.3.3.7 subject="$sitename: Usage at $percentage" body="This message is to inform you of your current usage for $sitename
 The current warning trigger is $warninglevel%.
 This site has downloaded $megsdowncurrent MB, which is $percentage%
 of the $gigs GB monthly download allowance.
 This is an Automatically generated E-mail
 that is sent out when users reach 50%, 75%, 90% and 100% of their cap.
 Traffic Monitor
 accounts@somewhere.com"
 :log info "Sent Warning Level $warninglevel% to $email"
 #Set new warning level on queue name
  /queue simple set $i name="$sitename!$gigs#$email!$newwarning"
==Monthly Report==
Called by the overseer at the end of the month, this generates reports for Every site and then resets counters and the warning level back to 00
 :local content
 :local i
 :local sitename
 :local gigs
 :local email
 :local megstotal
 :local totalcurrent
 :local percentage
 :log info "------ Begining Monthly Reports -------"
 /tool e-mail send to=$email from=something@somewhere.com server=1.3.3.7 subject="$sitename: Monthly Report" body="This message is to inform you of your full monthly usage for $sitename
 In this month this site has downloaded $megsdowncurrent MB, which is $percentage%
 This is an Automatically generated E-mail that is sent out at the end of each month.
 Traffic Monitor
 :log info "Sent end of month email for $sitename to $email"
 #Set warning level on queue name back to 00 and reset counters
  /queue simple set $i name="$sitename!$gigs#$email!00"
  /queue simple reset-counters $i
=Final Notes=
For those new to scripts, you can copy and paste these into winbox, but make sure that you at least remove the starting spacing from the comment lines (ones with #) if you don't they aren't treated as comments and will cause the script to error.
omega-00
Sun Jul 27, 2008 11:16 am
Just to clarify a little further, this script works based on an IP address instead of the usermanager system.
I've used queues for each IP to determine the usage.
You could do the same, so long as you had your DHCP server set to retain leases over 24hours but this is really made for a number of static addressed customers.
Regards,
Omega-00
heiko_s
Mon Jul 28, 2008 11:07 am
Hi Omega,
i finally got my script to work with the usermanager values. But for a warning, it would be very usefull to calculate the queues. We have a L4 licens for the usermanager - so there are just 20 acitve sessions with accurate up-to-date usesager values - the other values are calculated only at session end.
I could run your script once a hour for accurate usage warnings to the user.
I'll have a look at it soon ;o)
Thank you very much - great work!
Regards
Heiko
Users browsing this forum: No registered users and 7 guests
