sky
system auto upgrade
Tue Jul 22, 2008 2:36 pm
Hello!
Have a problem...
I'm trying to configure auto-upgrade script on RB112, 3.10
Script
/syst upgr refresh;
/syst upgr download-all;
: delay 600;
/system reboot;
But when I'm trying to run it, an error occurs:
run 0
 # SOURCE          NAME             VERSION      STATUS      COMPLETED
failure: there is no newer full release version available
But if I'm doing it manually, it works perfectly
/syst upgr pr
 0 10.10.10.201    routeros-mipsle  3.11         available
/system upgrade> pr
 0 10.10.10.201    routeros-mipsle  3.11         downloading 23%
Is there another way or any solution?
sky
Re: system auto upgrade
Fri Jul 25, 2008 12:23 pm
nobody knows?
Maybe there is another way to check out periodically, if newer version is available?
FOV
Sat Jan 03, 2009 7:43 pm
hi guys,
I've the same problem.
I've intalled 3.14 and if I run this command, the result is:
[XXXXXX@Dirhel_AR] /system upgrade> /syst upgr download-all;
even when 3.17 is released.
Some ideas?
Regards,
Fernando
Fernando
ARGENTINA
kbyrd
Thu Jul 21, 2011 3:09 am
Just came accross this post
that error is when all the installed packages dont match the packages on the remote router
so if you have one of those routing-test packages remove it or just donwload them all manually
i know this is old but just in case someone else stumbles accross this problem
for the people with the scripts just do a for eatch script that does download instead of download all
Users browsing this forum: No registered users and 12 guests
