AlpeRa
PHP API BUG ??
Tue Dec 23, 2008 9:18 am
[29] => Array
[.id] => *2A
[disabled] => no
[invalid] => no
[dynamic] => no
[name] => Queue1
[] => target-addresses
[255.1xx.xxx/32,88.255.1xx.xxx/32,88.255.1xx.xx] =>
[/32,88.255.1xx.xxx/32,88.255.1xx.xxx/32,88.255.1xx.] =>
[xx/32,88.255.1xx.xxx/32,88.255.1xx.xxx/32,88.255.] =>
[05.xxx/32] => dst-address
[0.0] => interface
[th
] => priority
[t-small!r] => .id
[29] => dst-address
[interface] => all
[e] => default-small/default-small
[led] => no
[.0.0.0/0] => dst-netmask
[ent] => TOPLAM
[default-small!r] => .id
[55.155.58/32] => dst-address
[0.0.0] => interface
[both
] => priority
[0/0] => max-limit
[isabled] => no
[0] => dst-netmask
[PLAM] => direction
[0] => max-limit
] => .id
[.128/27,212.175.xxx.xxx/28] => dst-address
[dst-netmask] => 0.0.0.0
] => priority
when i try to get data with multiple target-addresses from queue , i got the problem
how can i fix it?
when i try it with single target-address, it works
[30] => Array
[.id] => *32
[disabled] => no
[invalid] => no
[dynamic] => no
[name] => Queue2
[target-addresses] => 88.255.1xx.xx/32
[dst-address] => 0.0.0.0/0
[interface] => all
[parent] => TOPLAM
[direction] => both
[priority] => 8
[queue] => default-small/default-small
[limit-at] => 0/0
[max-limit] => 0/0
[total-queue] => default-small
moly
Re: PHP API BUG ??
Wed Jan 28, 2009 2:00 pm
Hi, I have the same problem. I try 3.15 and 3.19.
Error print :
!re >>> [8, 24] =.id=*19 >>> [9, 14] =comment= >>> [9, 4] =name=VPN >>> [128, 719] �=target-addresses=10.1.1.222/32,10.1.1.223/32,10.1.1.224/32,10.1.1.225/32,10.1.1.226/32,10.1.1.227/32,10.1.1.228/32,10.1.1.229/ >>> [51, 667] 2=dst-address=0.0.0.0/0=interface=all=parent=SG >>> [79, 587] slavany=direction=both=priority=5=queue=default/default=limit-at=256000/256 >>> [48, 538] 00=max-limit=8000000/8000000=burst-limit=0/0= >>> [98, 439] urst-threshold=0/0=burst-time=0s/0s=total-queue=default�!re=.id=*1A =comment= =name=VoIP_x1-=t >>> [97, 341] rget-addresses=10.1.1.240/32,10.1.1.241/32=dst-address=0.0.0.0/0=interface=all=parent=SG Oslav >>> [97, 243] ny=direction=both=priority=1"=queue=default-small/default-small =limit-at=0/0=max-limit=256000 >>> [47, 195] 256000=burst-limit=0/0=burst-threshold=0/0=b >>> [117, 77] rst-time=0s/0s=total-queue=default-small�
Martin Cerny
chairman of Oslavany.NET
moly
Re: PHP API BUG ??
Wed Jan 28, 2009 3:27 pm
I found error in read function. Problem with length calculation. This function work fine.
function read($parse = true) {
$STATUS = socket_get_status($this->socket);
$RESPONSE = array();
stream_set_timeout($this->socket, 2);
while (true) {
$tmp = ord(fread($this->socket, 1));
if ($tmp < 0x80) {
$LENGTH = $tmp;
} elseif ( $tmp < 0xC0) {
$tmp2 = ord(fread($this->socket, 1));
$LENGTH = ((($tmp*0x100)+$tmp2) ^ 0x8000);
} elseif ( $tmp < 0xE0 ) {
$tmp3 = ord(fread($this->socket, 1));
$LENGTH = ((($tmp*0x10000)+($tmp2*0x100)+$tmp3) ^ 0xC00000);
} elseif ( $tmp < 0xF0 ) {
$tmp4 = ord(fread($this->socket, 1));
$LENGTH = ((($tmp*0x1000000)+($tmp2*0x10000)+($tmp3*0x100)+$tmp4) ^ 0xE0000000);
if ($LENGTH > 0) {
$_ = fread($this->socket, $LENGTH);
$RESPONSE[] = $_;
if ($LENGTH > 0)
$this->debug('>>> [' . $LENGTH . ', ' . $STATUS['unread_bytes'] . '] ' . $_);
if ( (!$this->connected && !$STATUS['unread_bytes']) || ($this->connected && $_ == '!done' && !$STATUS['unread_bytes']) )
break;
if (($LENGTH == 0) and $STATUS['timed_out'])
break;
if ($parse)
$RESPONSE = $this->parse_response($RESPONSE);
return $RESPONSE;
Martin Cerny
stealth
Re: PHP API BUG ??
Sun Feb 01, 2009 3:57 pm
thanks for your fix for php read method. Right now I found out that there is some performance issues that some of you may also have.
It seems that certain commnans are very slow due to attempt to fread where there is no data.
/ip/firewall/filter/add=chain=FILTER-IN=dst-address=10.154.114.229=action=accept
/ip/firewall/filter/add=chain=FILTER-OUT=src-address=10.154.114.229=action=accept
/ip/firewall/filter/add=chain=FILTER-IN=dst-address=10.154.114.227=action=accept
/ip/firewall/filter/add=chain=FILTER-OUT=src-address=10.154.114.227=action=accept
each command sequence is blocked for 3 seconds which is default timeout value setted. I tried to add following condition at the end of while cycle, but in some cases it returns without data read, which are read in next read execution, so I get wrong response.
if (($LENGTH == 0 && !$STATUS['unread_bytes'])) {
   break;
Does anyone solved this performance issue ?
Users browsing this forum: Linuxvil and 20 guests
