bokad
How to pass variable between scripts
Tue Jan 27, 2009 6:34 pm
Is there any way to pass variables between scripts?
It seems that I can not access variables that are declared global in one script from another script.
Ex.
In script 1:
:global 64kdownload 64000
On the command line:
:environment print
shows: ""64kdownload"=64000
In script 3:
/queue type set "user-download" pcq-rate=$64kdownload
Script three will not run properly. Any ideas?
Letni
Re: How to pass variable between scripts
Wed Jan 28, 2009 3:17 am
SurferTim
Wed Jan 28, 2009 10:39 am
In the scripts that use global variables, but not change them, use this:
:global 64kdownload
janisk
Wed Jan 28, 2009 3:21 pm
to use global variable you have to declare it - if it is global and already have value - you will be able then access that value.
also note, that script should be in {} signs, or each line will count as separate script.
SurferTim
Wed Jan 28, 2009 4:13 pm
Pardon me, but I am not sure I understand. What do you mean by "separate script"? I know I use <?php ?> for php, but I saw nothing of the brackets in the examples. I use none in mine unless to group stuff. If I am doing something that may cause me challenges, I would like to know. Maybe a reference or wiki?
BTW I do not use the commands unless assigning them or getting a return value. So it would always be
:local returnval [/command]
I do not use
/command
anywhere.
WojtusW5
Thu Nov 29, 2018 4:38 pm
Hello, I have similar problem.
I have 2 script
name="test1" source=:global test "12345";
name="test2" source=:put $test;
And I can't display global variable from script
[admin@test] /system script> run test1
[admin@test] /system script> environment print
# NAME VALUE
0 test 12345
[admin@test] /system script> run test2
I invite you to visit my blog
https://mikrotikon.pl/
eworm
Long time Member
Long time Member
Fri Nov 30, 2018 1:08 am
I have 2 script
# NAME VALUE
0 test 12345
You have to declare it:
name="test2" source=:global test; :put $test;
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Fri Nov 30, 2018 8:12 am
To use variable from other script just re-declare the variable without initializing it.
script1
:global previousIP "1.2.3.4"
:put $previousIP
will display 1.2.3.4
script2
:global previousIP
:put $previousIP
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
sebastia
Fri Nov 30, 2018 9:23 pm
I pass values by using named variables, there is no need for globals here:
ex:
:local rtt [$getRTT target=$target intf=$intfP count=$pcount timeout=$ptimeout]
:global getRTT do={
#:log info "getRTT: target: $target, intf: $intf, count: $count, timeout: $timeout"
Jotne
Fri Nov 30, 2018 10:03 pm
If you read the title
You see that global is needed or you can write data to a file.
MikroTik->Splunk
sebastia
Sat Dec 01, 2018 9:33 pm
Actually I did see it, but ... if the scripts are related say script1 call on script2, named variables can be used.
If one can't call on the other then that won't fly naturally.
In other way, another option for a developer
Users browsing this forum: No registered users and 39 guests
