MUM Europe 2020
NAB
Trainer
Trainer
PHP API bug - expects '!done' as last data - this fix OK?
Tue Feb 17, 2009 11:52 am
When using the following code:
<?php
require('routeros_api.class.php');
$API = new routeros_api();
$API->debug = false;
if ($API->connect('1.2.3.4', 'apiuser', 'apipassword')) {
   $API->write('/tool/user-manager/user/add',false);
   $API->write('=name=fred',false);
   $API->write('=password=abc',false);
   $API->write('=add-credit=1h',false);
   $API->write('=group-name=low',false);
   $API->write('=subscriber=admin',false);
   $API->write('=comment=testing',false);
   $API->write('=disabled=no');
   $ARRAY = $API->read(false);
   print_r($ARRAY);
   $API->disconnect();
It loops forever as the read() function expects the last line of output to be "!done", whereas for this function, the last line is the return code (e.g. "=ret=*5") and the penultimate line is "!done".
I've cobbled together some changes which test for the existance of "!done" somewhere in the return values and then exit if there are no more characters left to read and we've already received "!done".
        function read($parse = true) {
                $RESPONSE = array();
                while (true) {
                        $LENGTH = ord(fread($this->socket, 1) );
                        if ($LENGTH > 0) {
                                $_ = fread($this->socket, $LENGTH);
                                $RESPONSE[] = $_;
                        if ($_ == "!done")
                                $receiveddone=true;
                        $STATUS = socket_get_status($this->socket);
                        if ($LENGTH > 0)
                                $this->debug('>>> [' . $LENGTH . ', ' . $STATUS['unread_bytes'] . '] ' . $_);
                        if ( (!$this->connected && !$STATUS['unread_bytes']) ||
                                ($this->connected && !$STATUS['unread_bytes'] && $receiveddone) )
                                break;
                if ($parse)
                        $RESPONSE = $this->parse_response($RESPONSE);
                return $RESPONSE;
My main worry with this approach is that if the line(s) following the "!done" are delayed, what happens then. Please can somebody with better PHP skills than me have a look and see if it can be optimised? If there's no response within a few days, I'll make the changes on the wiki.
Nick.
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
jalokim
Re: PHP API bug - expects '!done' as last data - this fix OK?
Thu Feb 19, 2009 1:09 pm
Nick,
Thanks for advise. I've just tring to export ppp/secrets using MT API - and I was able to do this only by 37 records.
After making your update all scecrets where exported just fine!
Mikolaj (Nick in english:))
janisk
Thu Feb 19, 2009 2:46 pm
NAB would be nice if you could add these to the wiki article about PHP API implementation or create a new article with fixes you have made. as this and proper return length calculation should be on the wiki.
NAB
Trainer
Trainer
Sat Feb 21, 2009 12:08 am
I have edited the original article - without the changes the PHP class simply doesn't work, so it makes no sense to keep the incorrect version listed.
Cheers,
Nick.
Users browsing this forum: No registered users and 20 guests
