jdleach
NetWatch scrip not work under RouterOS 3.10
Sat Apr 18, 2009 12:31 am
heres my up scrip
ip route set[find routing-mark=main] gateway=192.168.1.1
this scrip has work for years and on all upgrade until ver 3.10
any help would be great
skillful
Trainer
Trainer
Re: NetWatch scrip not work under RouterOS 3.10
Sat Apr 18, 2009 1:17 am
try
/ip route set [find routing-mark=main] gateway=192.168.1.1
jdleach
Sat Apr 18, 2009 1:50 am
I try your forward slash
it still dose not work :?
thanks for your reply skillful :)
skillful
Trainer
Trainer
Sat Apr 18, 2009 1:55 am
Copy the code to a terminal prompt and see if it works.
Alternatively, Upgrade to ROS3.22. It works for me.
jdleach
Sat Apr 18, 2009 3:19 am
well ROS 3.22 works again thx skillful :D
I did the upgrade on a test box and now I have to schedule maintenance downtime for my customers :wink:
SiB
Sat Mar 19, 2016 12:21 am
At v6.x you must use:
[admin@WAN] > /ip route set [ find where !routing-mark !dynamic ] gateway=192.168.1.1;
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB
Users browsing this forum: No registered users and 5 guests
