reeseshad
Manually Enable/Disable NAT Rules by Srcipting
Thu May 14, 2009 6:25 pm
I would like to know how to start writing scripts for the MikroTiK RB400. Is there a document that read to get started?
What I need to do is manually enabe/disable NAT rules from a browser or API interface(using a button). Is this possible? If so, what's the best scripting language to use?
Egate
Long time Member
Long time Member
Re: Manually Enable/Disable NAT Rules by Srcipting
Fri May 15, 2009 8:35 pm
Read wiki. Have got manual on script. Usually u use scheduler to run scrip when a condition is met. Don not know about from browser.
Happy days. :-)
jgellis
Fri May 15, 2009 9:14 pm
The API can certainly be used to accomplish what you are looking for. At the very top of this forum, there is a sticky topic to API Examples.
In addition, the following may provide you with some insight into what commands you may be able to execute from within the API:
http://wiki.mikrotik.com/wiki/Scripting
http://www.mikrotik.com/testdocs/ros/2. ... ipting.php
- If I helped you solve your problem... I am now able to accept tax-deductible Karma donations!
reeseshad
Wed May 20, 2009 9:59 pm
Thanks!! Your info really helped.
senzaroz
Tue Sep 25, 2018 11:07 am
Hi,reeseshad, where you able to create a webpage to enable/disable the NAT rules, this is what im looking for.
Users browsing this forum: No registered users and 17 guests
