randallr
Scheduler debugging?
Fri May 15, 2009 6:07 pm
I had two scheduler events on old MT box, and one isn't working after moving to new box.
Doesn't print file now:
/queue simple print stats file stats
Works fine still:
/queue simple reset-counters-all
I can execute the command from console and it makes the file, but not when scheduler executes.
I've created new scheduler entry from scratch and it will not either.
Don't know if there's any way to make log entry to show error?
Any suggestions?
randallr
Re: Scheduler debugging?
Fri May 15, 2009 6:49 pm
I'm wondering if this an issue with 3.23. (This is the first time I've tried on 3.23)
I've also tried running script with the same command, and it will not execute either
It only works from the command line on 3.23
I created scheduler event on several MT boxes with 3.22 and it works fine.
Chupaka
Sat May 16, 2009 9:05 pm
works as a script on v3.22. please write to support about this issue in v3.23
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
mrz
Mon May 18, 2009 8:24 am
check if you have set correct policies.
Users browsing this forum: No registered users and 20 guests
