Geoffb
Alter the default-configuration script
Mon May 18, 2009 4:47 pm
Hi Guys
I see there is a dead thread from 2008 where someone asked a similar question but the answer doesn't quite help me out.
http://forum.mikrotik.com/viewtopic.php?f=9&t=28169
I'm having an issue with 2 RB600s on a remote farm hill location. During bad weather there seems to be some sort of electrical build up or short which forces both boards back to factory defaults. This means a 1hr drive and 1hr hike up the mountain each time this happens.
Now I obviously need to address this electrical issue, but in the mean time I need to buy myself some time.
What I'm wanting to do is edit the default-configuration script so that when the boards reboot they automatically load a certain backup file. I can't use a standard script to do this because when it gets set to defaults all the scripts disappear, but the backup files remain.
Is it possible and how can I edit this default script?
Thanks.
DogHead
Re: Alter the default-configuration script
Tue May 19, 2009 7:43 am
You cannot alter the autorun.scr to my knowledge. This is a good request.
normis
Tue May 19, 2009 9:29 am
you can do it, default is whatever was used when using Netinstall to install RouterOS. Reinstall by adding a certain rsc file and that will become your default.
Users browsing this forum: Majestic-12 [Bot] and 33 guests
