noriel
3.24 API->disconnect
Mon Jun 01, 2009 3:01 pm
My problem goes like this. Im using php API to manipulate some data on my MT's using website. All was ok until now. On MT's with new OS (3.24) after disconnecting, the connection remain in "Active Connections" even though I use disconnect() function. Does anyone have a solution for this problem?
Chupaka
Re: 3.24 API->disconnect
Mon Jun 01, 2009 9:54 pm
seems like a bug. I have that problem too. MT Guys, is this known problem, or we should send supout? =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Tue Jun 02, 2009 9:57 am
no need, fix will be available in 3.25
noriel
Tue Jun 02, 2009 11:52 am
OK. Thanks
nandocapoeira
Wed Apr 13, 2011 9:43 pm
I'm using 4.11 and still having the same problem... This just was resolved?!
Fernando Oliveira
Chupaka
Wed Apr 13, 2011 10:02 pm
only in v5, unfortunately
ludvik
Fri Apr 15, 2011 1:23 am
Please! MT programmer, create patch for this problem in 4.x version. 4.17 has still bug in logout from API connection ("/user active" is a very very long list). Very please ...
Chupaka
Fri Apr 15, 2011 1:34 am
they won't backport it, unfortunately. v5 is current 'stable' version
Users browsing this forum: No registered users and 18 guests
