davidw
Multiple /tool fetch
Mon Jul 27, 2009 10:19 am
Hi There,
I wanted to fetch 4 files from an ftp server of mine.
I was hoping to be able to paste these commands into a terminal window. but it does not seem to work.
/tool fetch address=X.X.X.X src-path=/hotspot/logout.html dst-path=/hotspot/logout.html mode=ftp user=XXX password=XXX keep-result=yes port=21
/tool fetch address=X.X.X.X src-path=/hotspot/login.html dst-path=/hotspot/login.html mode=ftp user=XXX password=XXX keep-result=yes port=21
/tool fetch address=X.X.X.X src-path=/hotspot/status.html dst-path=/hotspot/status.html mode=ftp user=XXX password=XXX keep-result=yes port=21
/tool fetch address=X.X.X.X src-path=/hotspot/redirect.html dst-path=/hotspot/redirect.html mode=ftp user=XXX password=XXX keep-result=yes port=21
If I paste them in 1 at a time, they do work.
Any ideas ?
normis
Re: Multiple /tool fetch
Mon Jul 27, 2009 10:45 am
probably because you have to wait until the first transfer ends. you need some separator command between those.
davidw
Mon Jul 27, 2009 11:16 am
What is a separator command ?
Do you mean any command ?
I tried delay 2
Users browsing this forum: No registered users and 23 guests
