adilazzubaidi
help mrz
Mon Aug 10, 2009 7:56 pm
hi mrz any script to migrate hotspot users to userman users
dssmiktik
Forum Veteran
Forum Veteran
Re: help mrz
Wed Aug 12, 2009 11:10 am
you could write a script to parse hotspot users and run the command to import users into userman. It should be fairly trivial.
Doug
adilazzubaidi
Re: help mrz
Thu Aug 13, 2009 5:53 am
how?
mrz
Re: help mrz
Thu Aug 13, 2009 9:37 am
it's easy, for example get username and password and create user in usermanager
:foreach i in=[/ip hotspot user find] do={
   :local user [/ip hotspot user get $i name];
   :local pass [/ip hotspot user get $i password];
   /tool user-manager user add name=$user password=$pass subscriber=admin
adilazzubaidi
Re: help mrz
Fri Aug 14, 2009 7:31 pm
thanks and what about for mac address and ip
fewi
Re: help mrz
Fri Aug 14, 2009 7:45 pm
   :local ip [/ip hotspot user get $i address];
   /tool user-manager user add name=$user password=$pass ip-address=$ip subscriber=admin
user-manager doesn't have a field for MAC addresses.
Hope that helps,
Felix
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
adilazzubaidi
Re: help mrz
Fri Aug 14, 2009 8:51 pm
userman v4b4 contains caller ID (mac address)
fewi
Re: help mrz
Fri Aug 14, 2009 9:09 pm
Then add
:local mac [/ip hotspot user get $i mac-address];
and change the insert
/tool user-manager user add name=$user password=$pass ip-address=$ip whatever-property-holds-the-mac-address=$mac subscriber=admin
dssmiktik
Forum Veteran
Forum Veteran
Re: help mrz
Sat Aug 15, 2009 12:13 am
Then add
/tool user-manager user add name=$user password=$pass ip-address=$ip caller-id=$mac subscriber=admin
The caller-id field also works when tested on 3.25 - 3.28.
Doug
Users browsing this forum: No registered users and 46 guests
