jone8880
How to?: dynamic purpose of the public IPs via NAT
Tue Aug 18, 2009 8:22 pm
I've use mikrotik like boarder gate, shaper, bgp. My billing via ssh do only one thing - add and remove ip address "X" to address-list "Y". Now I need dynamic assign public ip adresses for local adresses from address-list via NAT. For example: pool "one" 95.95.95.0/24. When 192.168.1.1 add to address list "one". Script must make next:
1) get free ip from pool "one"
2)make 2 nat rules: src-nat 192.168.1.1 to 95.95.95.100; dst-nat 95.95.95.100 to 192.168.1.1
3) when ip 192.168.1.1 remove from address list "one" - - nat rules must remove.
How to do it?
Chupaka
Re: How to?: dynamic purpose of the public IPs via NAT
Thu Aug 20, 2009 4:21 am
I think, it's easier, if your billing via ssh will do one more thing - add and remove NAT rules =)
it's even more logical
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jone8880
Fri Aug 21, 2009 1:23 am
many operation step-by-step.. in 5 time more..possible will sending 5 line in one frame via ssh?
fewi
Fri Aug 21, 2009 1:31 am
Pool management can be surprisingly tricky to script. How do you determine that an address is unused and is available for 1:1 NAT? What happens if a customer extends a contract but the IP address is already booked for someone else? Certainly doable, but some work.
If at all possible I think it'd be much easier if you simply didn't NAT those addresses but rather implemented a second network (VLAN?) that is all public for customers that require public addresses. Then you're back to just adding addresses to adress-lists to permit traffic for them.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
fewi
Fri Aug 21, 2009 1:41 am
Though I guess if you can spare the publics and don't ever use them for anything else, another alternative would be to simply 1:1 NAT all the public IPs you have to known private IPs, and to always keep those rules. Just don't assign those privates to any customer that didn't pay for a public. If you have no other use for the publics, why dynamically configure them every time?
Users browsing this forum: WojtusW5 and 57 guests
