erazor999
PHP API connection
Sat Nov 28, 2009 12:45 pm
I have problem with connecting to MikroTik with this $API->connect!!!
Sometimes connect, sometimes not!!!
Connection attempt #1 to 10.2.2.7:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 39] !done
>>> [37/37 bytes read.
>>> [37, 1] =ret=e468307e9a81295c12141bd7ddc805f4
Connection attempt #2 to 10.2.2.7:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 39] !done
>>> [37/37 bytes read.
>>> [37, 1] =ret=1c2341c8123f35583fe82073525b99bc
Connection attempt #3 to 10.2.2.7:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 0] !trap
Connection attempt #4 to 10.2.2.7:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 31] !trap
>>> [29/29 bytes read.
>>> [29, 1] =message=cannot get challenge
Connection attempt #5 to 10.2.2.7:8728...
<<< [6] /login
>>> [5/5 bytes read.
>>> [5, 31] !trap
>>> [29/29 bytes read.
Error...
janisk
Re: PHP API connection
Mon Nov 30, 2009 1:25 pm
how many concurrent connections through API you already have to this router?
omidkosari
Trainer
Trainer
Sat Apr 24, 2010 7:50 pm
I am also using http://wiki.mikrotik.com/wiki/API_PHP_class . it worked good but after some hours API returned cannot get challenge and then script could not connect to API anymore .
Another strange thing is , i have seen a lot of sessions in "/user active print" . there are more than 44500 :shock: sessions there from user which i used for API connection but i have used $API->disconnect () .
RouterOS v4.7
SurferTim
Sat Apr 24, 2010 10:28 pm
You aren't following that example literally, are you? It does a login, one command, then logs out. You can log in once, do as many commands as you need to do, then disconnect (logout) once when you are finished for the session.
Maybe a "/quit" command sent just before the disconnect might drop the user from the active list.
omidkosari
Trainer
Trainer
Sun Apr 25, 2010 8:46 am
The script runs each time the specific page hits by a user so it should login , execute the command and then logout . the only way is a persistent connection with something like CURL or pfsockopen which needs customization of API_PHP_Class .
Tried but unfortunately not worked :(
omidkosari
Trainer
Trainer
Sun Apr 25, 2010 10:05 am
I have also test with mikrotik official python api client . it has same problem and does not clear the admin from "/user active print" .
even after sending /quit . with /quit it successfully closes the connection and raises "connection closed by remote end" but the admin is still remains alive at "/user active print" .
dssmiktik
Forum Veteran
Forum Veteran
Sun Apr 25, 2010 10:34 am
The /user active list is directly tied to /ip firewall connection table for that service (from what I've found).
There are still connections in the connection table connecting to API.
If you remove the connection from the connection table, the /user active entry is also removed.
SurferTim
Sun Apr 25, 2010 2:35 pm
I recommend you run that script a few times and check that there are at least a few entries in "/user active". Then make a supout file and email to support (at) mikrotik.com with a short explanation of the problem, and what you tried (disconnect and /quit).
omidkosari
Trainer
Trainer
Mon Apr 26, 2010 8:33 am
I will follow this topic at http://forum.mikrotik.com/viewtopic.php?f=2&t=41200 because that board is more popular
janisk
Mon Apr 26, 2010 10:26 am
this is know problem. and we are working to correct it.
Only reliable way to get out those ghosting entries is to reboot the router.
omidkosari
Trainer
Trainer
Mon Apr 26, 2010 10:55 am
As a programmer can you suggest a way to persistent the connection for preventing this problem temporary ?
janisk
Mon Apr 26, 2010 12:44 pm
for time being - see at what number of connections it fails and reboot router slightly before that number. Not much of a workaround.
omidkosari
Trainer
Trainer
Mon Apr 26, 2010 12:50 pm
It is a random number
janisk
Mon Apr 26, 2010 1:06 pm
10k - 20K worked for me.
astounding
Mon Apr 26, 2010 8:30 pm
That must be true, for on an RB411 with connection tracking disabled (no NAT, just bridging and/or simple routing) running 4.5, repeated API connect/command/disconnect sessions do not accumulate, but behave as expected. (Using the Ruby API library, but the library/language doesn't matter.)
webasdf
Thu Jul 01, 2010 6:55 pm
I have this problem with new 4.10 firmware. This problem does not happen in 4.5. I'm not sure which firmware re-introduced the bug.
zemnet
Fri Jul 09, 2010 9:05 pm
4.10 me also,
wbarbaresco
Wed Sep 15, 2010 2:31 pm
4.10 for me to
dssmiktik
Forum Veteran
Forum Veteran
Fri Oct 08, 2010 3:37 am
v4.11 x86 is also not disconnecting correctly. Also, I use NAT and there are no connections to API (8728) on the router.
I will continue to use SSH/Telnet, it's very solid.
Doug
janisk
Fri Oct 08, 2010 9:38 am
problem with disconnects persist through all the versions since it was introduced while fixing critical bug. And, sadly, it is still open for version 4.x
It is fixed for 5.x
dssmiktik
Forum Veteran
Forum Veteran
Fri Oct 08, 2010 1:09 pm
janisk,
Thank you for the update. :-) I look forward to v5
Doug
taduikis
Sat Oct 09, 2010 11:38 am
Yeah, I'm too looking forward to stable final v5 release :(
Currently I have found no means to overcome this problem, I also can't find entries to remove in ip firewall connections list.
SpectatorCN
Tue Oct 12, 2010 12:31 am
I had the same problem with the API for version 4.10.
To test did downgrade one server to 4.5, and another server updated to 5.0rc1.
And they both work without the above problems. Almost. ))
In one week, both servers had to reboot.
In 5.0rc1 and in version 4.5 session disappear good.
BUT in an uncertain time MT simply stops responding through the API.
Here's waiting for the repetition ...
As a solution to the problem may be reboot MT via telnet from remote script.
--- Do not like my English - do not read my messages. ---
Родился в СССР, живу на Украине, говорю по русски, пишу на английском. :)
taduikis
Tue Oct 12, 2010 12:24 pm
So what's so different between versions 4.5 and 4.11?
Can we actually expect this to be somehow fixed in next 4.x version?
janisk
Tue Oct 12, 2010 3:28 pm
both, rc1 and 4.5 stop responding or just 4.5, older versions had that problem in rc1 it should have been fixed.
dssmiktik
Forum Veteran
Forum Veteran
Tue Oct 12, 2010 8:36 pm
I think work is going into v5.x I don't believe this problem will be fixed in v4.x IMO
Doug
janisk
Wed Oct 13, 2010 2:53 pm
if you remember broken console in RouterOS 5.0beta2 then that was caused by that patch. That is why it is not yet there in version 4
AlexLV
Fri Jan 14, 2011 11:59 am
Very sadly that problem as i understand can't be solved in v4, i have same problem in latest v4.16.
omidkosari
Trainer
Trainer
Thu Mar 03, 2011 6:48 pm
anybody tests this problem in 5.0rc11 ?
taduikis
Thu Mar 03, 2011 8:25 pm
Of v5 final we wait.
janisk
Mon Mar 07, 2011 10:46 am
what problem exactly?
If you talk about idling connections in active list - it has been fixed in 5.0beta2
omidkosari
Trainer
Trainer
Mon Mar 07, 2011 11:14 am
janisk
Mon Mar 07, 2011 11:19 am
yes, it is the same. in all versions since 5.0beta2 till 5.0rc11 this problem of active API sessions accumulating has been solved.
Users browsing this forum: Google [Bot] and 35 guests
