piwi3910
ipsec dynamic ip script
Wed Jul 27, 2005 2:07 pm
eugene one sended me this
Posted: Thu Aug 12, 2004 2:47 pm Post subject:
I would configure something like the following:
/ip ipsec peer add address=1.1.1.2 secret=qazwsxedc generate-policy=no
/ip ipsec policy add sa-src-address=0.0.0.0 sa-dst-address=1.1.1.2 action=encrypt tunnel=yes <src- and dst- addresses as appropriate>
/system script add name=addr-refresh source={:foreach i in=[find] do {:if ([/ip address find address=[/ip route get $i preferred-source]]!="") do {:if([/ip address get [/ip address find address=[/ip route get $i preferred-source]] address]=[/ip dhcp-client lease get address]) do {:if ( [/ip ipsec policy get [/ip ipsec policy find sa-dst-address=1.1.1.2] sa-src-address] != [/ip route get $i preferred-source]) do {/ip ipsec policy set [/ip ipsec policy find sa-dst-address=1.1.1.2] sa-src-address=[/ip route get $i preferred-source] }}} }}
/system scheduler add name=run-15s interval=15s on-event=addr-refresh
it was to make ipsec connections from a dynamic ip adress to a static one...
but the script just doesn't work, i really tried everything... but i just don't see the fault...
i get this...
no sutch command or directory (find)
can someone check this
thxs
pascal
Eugene
Forum Veteran
Forum Veteran
Thu Jul 28, 2005 11:42 am
/system script add name=addr-refresh source={:foreach i in=[/ip route find] do {:if ([/ip address find address=[/ip route get $i preferred-source]]!="") do {:if([/ip address get [/ip address find address=[/ip route get $i preferred-source]] address]=[/ip dhcp-client lease get address]) do {:if ( [/ip ipsec policy get [/ip ipsec policy find sa-dst-address=1.1.1.2] sa-src-address] != [/ip route get $i preferred-source]) do {/ip ipsec policy set [/ip ipsec policy find sa-dst-address=1.1.1.2] sa-src-address=[/ip route get $i preferred-source] }}} }}
However if you use 2.9 version there is a much shorter and simplier way to accomplish this.
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
piwi3910
mmmh not working still
Thu Jul 28, 2005 2:19 pm
i understand what you are trying to do with this script, but it's still not working.
i made the policie with the correct sa-dst-address
i changed the sa-dst-address in the script to the correct ip adress.
it doesn't give me any errors in the log file, but still my policie is't changed to put the sa-src-address to the correct ip address.
how do you start debugging someting like this?
you can't get any output.
Eugene
Forum Veteran
Forum Veteran
Thu Jul 28, 2005 3:02 pm
Remove everything and start from the outer loop. Place print commands to see the output and change them later with the actual constructs if they give expected output.
BTW, I suggest to upgrade to 2.9 - there are new scripting commands which made this task a piece of cake.
tneumann
Fri Jul 29, 2005 4:57 pm
Which, I assume, would be generate-policy=yes ?
--Tom
Eugene
Forum Veteran
Forum Veteran
Fri Jul 29, 2005 5:17 pm
Nope, it works only if one endpoint has dynamic IP.
FOV
Wed Dec 28, 2005 8:24 pm
Eugine, hi. I´m trying to do the same.
On one point I´ve a MTK with Dynamic IP, and on the other side, a Hotbrick with Dynamic IP to.
I´m looking for a script in order to actualize the policy.
Can you help me pls?
I´m using a Router board 500 with OS. 2.9.8
Rgs,
Fernando
Eugene
Forum Veteran
Forum Veteran
Thu Dec 29, 2005 6:46 pm
Read my previous posts.
viceft
ipsec
Sat Mar 04, 2006 6:03 am
how know in the central site (ip static) what is the ip from remote site?
Eugene
Forum Veteran
Forum Veteran
Sat Mar 04, 2006 1:08 pm
If one of the endpoints has a static IP address, just do not create the policy on this endpoint. Instead, set generate-policy=yes in its peer record.
blaze888
Re: ipsec dynamic ip script
Tue Jun 09, 2009 9:15 am
im having same troubles here.. any inputs would be great!
Thanks!
assurance vie
hacki
Thu Dec 03, 2009 7:07 pm
hi there,
standing in front of the same issue with dynamic ip adresses and ipsec.
has already someone running such a scenario?
greets
Users browsing this forum: codered1983, mhmo567 and 54 guests
