MUM Europe 2020
jalokim
[PHP] When API will work ?
Tue Feb 16, 2010 9:26 pm
Since begening I have problems with API.
In log I have:
and:
So API user is not logged off.
My PHP code is:
function blokada_www($typ,$ip,$lista)
	include_once('mt/ros_api.php');
	$API = new routeros_api();
	$API->debug = false;
	if ($API->connect('host', 'user', 'pass'))
		if($typ == "usun")
			$API->write('/ip/firewall/address-list/getall');
			$READ = $API->read();
		   $array = $API->parse_response($READ);
			for($x=0;$x<count($array);$x++)
				if(array_search($ip, $array[$x]))
					if($array[$x]["list"] == $lista)
						$API->write('/ip/firewall/address-list/remove',false);
						$API->write('=.id='.$array[$x][".id"],true);
						$odp = $API->read();
						if($odp[0] == "!done") return TRUE;
			$API->disconnect();
		elseif($typ == "dodaj")
				//echo $x."-".$array[$x]["list"]."-".$lista." | ".$array[$x]["address"]."-".$ip."<br>";
				if($array[$x]["list"] == $lista && $array[$x]["address"] == $ip)
					//echo "Adres ".$array[$x]["address"]." jest juş na li�cie ".$lista;
					$count++;
					return TRUE;
			if($count == 0)
				$API->write('/ip/firewall/address-list/add',false);
				$API->write('=list='.$lista,false);
				$API->write('=address='.$ip);
			$API->disconnect();
My question is:
Why sometimes this works, and somethimes not?
Chupaka
Re: [PHP] When API will work ?
Wed Feb 17, 2010 12:30 am
what version of ROS do you use?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Wed Feb 17, 2010 11:07 am
API log off is equal to closing connection, if you do not do that proper way, USER will stay logged in if logged through API
also /quit exists
jalokim
Wed Feb 17, 2010 1:21 pm
3.30
jalokim
Wed Feb 17, 2010 1:22 pm
also /quit exists
On every
if
there is
$API->disconnect();
so what else shoud i do?
Users browsing this forum: No registered users and 22 guests
