martini
Cant read file large then 4085 bytes
Wed Apr 28, 2010 11:28 am
Try to use this script
:global content [/file get [/file find name=test.txt] contents] ;
:global contentLen [ :len $content ] ;
:global lineEnd 0;
:global line "";
:global lastEnd 0;
:do {
       :set lineEnd [:find $content "\r\n" $lastEnd ] ;
       :set line [:pick $content $lastEnd $lineEnd] ;
       :set lastEnd ( $lineEnd + 2 ) ;
       :local tmpArray [:toarray $line] ;
	:if ( [:pick $tmpArray 0] != "" ) do={
	:put $tmpArray;
         /ppp secret add name=[:pick $tmpArray 0] password=[:pick $tmpArray 1] \
             local-address=[:pick $tmpArray 2] remote-address=[:pick $tmpArray 3] \
             profile=[:pick $tmpArray 4] service=[:pick $tmpArray 5];
} while ($lineEnd < $contentLen)
But if file large then 4085 bytes nothing happens
Can somebody help with this ??
mrz
Re: Cant read file large then 4085 bytes
Wed Apr 28, 2010 11:38 am
This is current limitation, and there is no workaround
Next time use search:
http://forum.mikrotik.com/viewtopic.php ... it#p202842
dssmiktik
Forum Veteran
Forum Veteran
Wed Apr 28, 2010 11:45 am
If the file contents can not be read (due to file size limitation), an empty string is returned.
You could try adding this if file contents cannot be retrieved:
+ :if ([:len $contentLen] = 0) do={
+    :error ("Could not retrieve test.txt contents")
:global lineEnd 0;
:global line "";
:global lastEnd 0;
:do {
   :put $tmpArray;
Doug
dynek
Fri Apr 15, 2016 3:11 pm
6 years later, 4kb is still the max size of files that can be read from a Mikrotik's script?
This sounds like April's Fool and makes me go back to what computers used to be 30 years ago.
jarda
Fri Apr 15, 2016 4:19 pm
Even 30 years ago there was not such low limit as I remember.
dssmiktik
Forum Veteran
Forum Veteran
Sat Apr 16, 2016 6:47 am
I believe it may have something to do with the buffering mechanism being used to fetch / stream data. At one point, I thought this limitation applied to comments as well, but I think that is no longer the case.
Regardless, it would be nice to at least see some streaming API, even if we an only buffer 4kb chunks, we could eventually read / write the entire contents of a file.
Doug
midenok
Mon Apr 25, 2016 7:40 pm
Hey, this means I can't parse files??? No other ways to read by chunks? I want to parse http://txt.proxyspy.net/proxy.txt
RouterOS 6.34
dssmiktik
Forum Veteran
Forum Veteran
Tue Apr 26, 2016 5:54 am
Unfortunately not if the contents is > 4kb.
You could setup an external service to transform the data into a RouterOS string via local variable. This would allow you to consume the entire file, provided enough memory. If the file already exists on the router, you could use fetch to ship the file to the external service, and retrieve streaming data that way. This is not ideal, but well,it works.
Doug
midenok
Tue Apr 26, 2016 8:37 am
Nah, much simpler is to run perl under metarouter. But I'm amazed how primitive and lame routerscript is. It literally can't do something a little bit more complex than 2+2. And if it by some star confluence can, then it will be big pain and shaman dances...
RouterOS 6.34
macsrwe
Long time Member
Long time Member
Fri May 13, 2016 10:10 am
:-x !!!
I just wasted five hours tonight writing a script to be periodically run on every one of our routers (including CPEs) to update common configuration scripts if newer versions of those scripts were available on a server.
Because FTP fetch doesn't preserve the date-modified of the source file, it had to depend on being able to determine if the contents of file A were or were not equal to the contents of file B. I tested this out before spending time writing the script, but the files I tried it out on were smaller files and so they worked correctly. I finished the entire script before I discovered that ROS always told me that the files were equal whether or not it was true. That's five hours wasted that I could have used to make progress on something else. And I'm stuck with the conclusion that there is absolutely no other way to do what it is I needed to do.
Users browsing this forum: No registered users and 11 guests
