kazanova
script
Mon May 10, 2010 7:41 pm
my ip rang 192.168.10.0/24
and i simple queue
but this script
can someone help me
i don't know from where i should start
thx for try
:local traf;
/queue simple
:for i from=1 to= 254 do = {
:if ([/queue simple find target-addresses=("192.168.10." . $i)] != "") do={
:set traf [get [find target-addresses=("192.168.10." . $i)] total-bytes]
:if ($traf > 1048500) do = {
set [find target-addresses=("192.168.10." . $i)] max-limit=
انا انزلنا التوراه فيها هدى ونور يحكم بها النبيون الذين اسلموا للذين هادوا والربانيون والاحبار بما استحفظوا من كتاب الله وكانوا عليه شهداء فلا تخشوا الناس واخشون ولا تشتروا باياتي ثمنا قليلا ومن لم يحكم بما انزل الله فاولئك هم الكافرون
kazanova
Re: script
Mon May 10, 2010 9:40 pm
i use RO 3.30
but no script run fine why??
:for i from=2 to=254 do={/queue simple add name="172.16.64.$i"
target-address="172.16.64.$i/32" max-limit="256000/800000"
burst-limit="0/1500000" burst-threshold="0/400000" burst-time="0s/1m"}
janisk
Re: script
Tue May 11, 2010 1:26 pm
use PCQ and set 1 simple queue that will limit all the users in network. For examples please take a look on wiki and search in forum.
kazanova
Re: script
Tue May 11, 2010 7:37 pm
janisk thx
i had take many look :D
simple i wan to know why script don't work with me
i like to know more about script
i know about PCQ
dssmiktik
Forum Veteran
Forum Veteran
Re: script
Wed May 12, 2010 4:20 am
A few things I noticed:
1) I usually don't put spaces between 'do={'
2) specify a max-limit when setting the queue.
Try this code: (replace FIXME with a max-limit value)
:local traf;
/queue simple
:for i from=1 to=254 do={
         set [find target-addresses=("192.168.10." . $i)] max-limit=FIXME
Doug
kazanova
Re: script
Wed May 12, 2010 6:12 pm
it come like that but no hope
any idea what could be the problem
:local traf;
/queue simple
:for i from=10 to=15 do={
:if ($traf < 1048500) do = {
set [find target-addresses=("192.168.10." . $i)] max-limit=16000/16000
dssmiktik
Forum Veteran
Forum Veteran
Re: script
Wed May 12, 2010 11:38 pm
Here is the corrected version (my last post wasn't quite the correct version):
Again, (replace FIXME with a max-limit value):
:local traf;
/queue simple
      :if ($traf > 1048500) do={
Doug
kazanova
Re: script
Fri May 14, 2010 6:04 pm
had you test it ??
dssmiktik
Forum Veteran
Forum Veteran
Re: script
Fri May 14, 2010 7:57 pm
Does the latest post work for you?
Doug
kazanova
Re: script
Fri May 14, 2010 7:58 pm
no one work with me :S
dssmiktik
Forum Veteran
Forum Veteran
Re: script
Sat May 15, 2010 5:44 am
Here is the exact script I tested, and it worked on v4.8 x86:
:local traf;
/queue simple
Doug
kazanova
Re: script
Tue Jul 06, 2010 7:33 pm
it dont work with me
i have v3.30 do u think that will cuz tobrok this scrpit
NAB
Trainer
Trainer
Re: script
Tue Jul 06, 2010 7:39 pm
How are you running the script and what error message do you get?
psamsig
Re: script
Wed Jul 07, 2010 11:16 am
I think the problem was in the matching of the target address, it lacked the '/32' suffix
/queue simple {
      :local o [find target-addresses=("192.168.10." . $i . "/32")]
      :if ($o != "") do={
         :if ([get $o total-bytes] > 1048500) do={
            set $o max-limit=16000/16000
kazanova
Re: script
Fri Jul 09, 2010 3:39 pm
13 post
274 viwe
thx for every one
but psamsig u get karam + thx
Users browsing this forum: No registered users and 21 guests
