bigguns
Email on high Temperature script not working
Mon Jun 14, 2010 2:26 am
Hi there,
I'm trying to create a high temperature script but when I receive the email I don't get a temperature display. Could someone take a look please.
/system health
:if ([get temperature]>70) do={/tool e-mail send to="XXXXX@XXXXXX" subject=[/system identity get name] body=("High temperature. Current temperature is :".[/system health get temperature])} else {:log info "temperature is ok."}
Chupaka
Re: Email on high Temperature script not working
Mon Jun 14, 2010 2:39 am
seems okay. what if
is changed to
{:log info ("temperature is ok.".[/system health get temperature])}
what version do you use?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
bigguns
Mon Jun 14, 2010 8:52 am
Thanks for your input I'll give it ago when I have access to the unit.
I'm actually running v4.10.
bigguns
Mon Jun 14, 2010 9:22 pm
hmm ok - I've tested the script:
:if ([get temperature]>10) do={/tool e-mail send to="XXX@XXXX" subject=[/system identity get name] body=("High temperature. Current temperature is :".[/system health get temperature])} else {:log info ("temperature is ok.".[/system health get temperature])}
But it seems now I'm not getting any emails nor is it working correctly - in the RB log it just stating temperature ok.
Chupaka
Mon Jun 14, 2010 9:28 pm
/system health print
do you see the temperature on that router at all?..
bigguns
Mon Jun 14, 2010 9:39 pm
Yes it I can see it either through winbox or terminal - and it works fine there.
Chupaka
Mon Jun 14, 2010 9:46 pm
works fine for me on v4.10, RB450G:
18:45:18 script,info temperature is ok.31
bigguns
Mon Jun 14, 2010 9:58 pm
Ok I've tested it again - RB450G - works fine.
But on the issue RB800 - doesn't work.
Both 4.10v and latest bootloader.
bigguns
Tue Jun 15, 2010 12:06 am
I've been playing around with this more and I believe it must be a bug in the firmware, as to why its not reporting correctly.
I'll send it over to MK.
Chupaka
Tue Jun 15, 2010 12:22 am
sounds a bit crazy...
please post the result here =)
mrz
Tue Jun 15, 2010 9:49 am
:if ([get cpu-temperature ]> 10) do={ ... }
janisk
Tue Jun 15, 2010 10:00 am
the problem is, RB800 have CPU probe, so reported temperature is actually cpu-temperature, while RB540G have on-board probe, that reports ambient temperature near some hot parts and is reported as temperature. It is done so to reduce confusion in case there is board with both probes.
bigguns
Tue Jun 15, 2010 10:32 am
Thank you!
januszzz
Thu Jun 17, 2010 1:29 am
Hi there,
btw: is there an OID to get the rb800 CPU temperature at all? I don't see it in Mikrotik.mib.
fewi
Thu Jun 17, 2010 2:01 am
Hi there,
[admin@MikroTik] /system health> print oid
   active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
      voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
  temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
Users browsing this forum: No registered users and 10 guests
