kazanova
128+128=256???
Tue Jun 22, 2010 8:52 pm
could be have 128+128=256
pcc no any other can??? bonde???
Chupaka
Re: 128+128=256???
Tue Jun 22, 2010 8:57 pm
yesss, bonding in RR mode =) but only on low-latency links, and only if you control both sides of the link
kazanova
Re: 128+128=256???
Tue Jun 22, 2010 9:00 pm
peleas explaen more about low-latency and control both sides
so the bonding better than pcc ????!!!
Chupaka
Re: 128+128=256???
Tue Jun 22, 2010 9:04 pm
if those links are between your routers - you may bond them. if you use RR mode on high-latency links, packet reordering may occur. it's bad =)
PCC and bonding are for different goals. bonding has nothing to do with load balancing
Users browsing this forum: No registered users and 34 guests
