baddah
Auto configure through Mac Telnet
Tue Jun 29, 2010 2:05 pm
I'm trying to setup the following.
I use one routerboard as a 'configuration routerboard'. From here i will mac telnet to default (unconfigured) routeboard plugged into the network, and run a configuration script that will setup the new routerboard.
I'd like to do all of this automatically. Is ther any way to run a script from this configuration routerboard through Mac Telnet on the new routerboard,i.e no need to first mac telnet,enter username/password and then upload script.
I want to connect and run the script automatically using some command string, so that i can run it through our API to the configuration routerboard.
Any ideas/suggestions?
Chupaka
Re: Auto configure through Mac Telnet
Tue Jun 29, 2010 4:22 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Percanta
Wed Jun 30, 2010 3:42 pm
i've done flashfig so log shows flashfiged , i power off and power on the RB but the configuration is the same of before, i dont know what it is, ive tryed differente script diferente RB same results
any idea?
thx
Users browsing this forum: No registered users and 15 guests
