brof
GPS Email Script - Anyone
Thu Jul 22, 2010 3:40 am
I have been searching all the forums yet I am unable to find any scripts for GPS location emails.
I have a GPS on serial0 and would love to setup a script to email its position each day at 7am?
So far I am able to create a file called "gps.txt" with the lat and longs from the GPS.
Could someone help me with sending that file in a email once every 24 hours with the heading of the email the identity of the radio...
Please can anyone help...?
Cheers
SurferTim
Re: GPS Email Script - Anyone
Sun Jul 25, 2010 1:21 pm
First you should insure your router is set correctly to send email. Set the server and from address in "/tool e-mail". Then try a test.
/tool e-mail
send to=me@mydomain.com subject="GPS test" body="GPS test" file=gps.txt
Then you can enter the same line in a script. Schedule it to run every 24 hours.
brof
Mon Jul 26, 2010 6:36 am
Thanks Tim, that worked a treat.....
brof
Mon Jul 26, 2010 9:52 am
Anyone know how to import this automatically to google maps or google earth ???
gps.txt file contains the following # jul/26/2010 14:32: 8 by RouterOS 5.0beta4
# software id = SYPQ-LP73
date-and-time: jul/26/2010 04:32:07
longitude: "E xxx x' xx''"
latitude: "S xx xx' xx''"
altitude: "223.800003m"
speed: "0.000000 km/h"
valid: yes
satellites: 8
normis
Mon Jul 26, 2010 8:09 pm
don't cross post! stick to one topic
Users browsing this forum: No registered users and 25 guests
