promind
Help about web auth
Thu Sep 16, 2010 12:48 pm
Hi all,
My provider has a web auth enabled and I must login every time I reboot the MT.
Is there any chance MT to autologin?
Here is HTML source of there login form:
<div><h3>Активиране</h3><div id="ws"><form name="auth" method=post action="http://91.139.151.3/scr/login" autocomplete="off"><table border=0><tbody><tr><th>Потребител:</th><td><input name="user" type="text" class="search" size=10></td></tr><tr><th>Парола:</th><td><input name="parm" type="password" size=10></td></tr></tbody></table><input name="hs" type="hidden"><input name="p" type="hidden" value="log"><input name="ht" type="hidden" value="a7fcd41384b225908eca401ccf884a51"><br><center><input name=regsend value="Активирай" type="submit" onclick=showDiv();></form></div></div></div></div></div></div></div></td><td width=40>&nbsp;</td><td valign = top > <div id="hide"> <br><center>
I would really appreciate a little help with scripting since I have never wrote MT scripts.
mrz
Re: Help about web auth
Thu Sep 16, 2010 12:50 pm
It is not possible to build a packet with RouteroS script.
promind
Thu Sep 16, 2010 4:35 pm
isn't there any embedded browser that can do the job?
mrz
Thu Sep 16, 2010 4:52 pm
unfortunately no
ditonet
Forum Veteran
Forum Veteran
Fri Sep 17, 2010 1:05 am
For windows boxes is scripting utility which can automate your login process
http://www.autoitscript.com/autoit3/index.shtml
I don't know that is something similar for linux.
Regards, Grzegorz.
Grzegorz | MTCNA, MTCRE, MTCSE, MTCSWE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
tonyclark
Wed Feb 10, 2021 10:13 am
Maybe you can automate the setup + copying the access files with this:
https://fastautoclicker.com/
(Don't ask me how. I just know that theoretically it should work).
Users browsing this forum: Google [Bot] and 18 guests
