andrescamino
Insert into text file some text from a script
Thu Dec 23, 2010 7:15 pm
How can I insert into a text file some information for example I would like to insert into different lines the numbers 1 to 10 into a text file and save it into the files.
/file print file=Number
/file set Number.txt contents=" "
:for i from=1 to=10 do={ :put $i }
but instead of showing that on the terminal everytime I run it...I would like it to be saved on the contents of Number file in different lines...
mrz
Re: Insert into text file some text from a script
Thu Dec 23, 2010 7:20 pm
 :local tmp "";
 :for i from=1 to=10 do={ :set tmp "$tmp\r\n$i" }
 /file set Number.txt contents=$tmp
andrescamino
Thu Dec 23, 2010 7:29 pm
Tks mrz...it works just like i wanted..
Users browsing this forum: brunolabozzetta, Pilo2710 and 29 guests
