AnRkey
Syntax hi-lighting
Tue Apr 05, 2011 11:38 pm
Hi
Is there a way to enable syntax hi-lighting while editing scripts like in the console? If not, where do I submit a feature request?
R
MTCNA
janisk
Re: Syntax hi-lighting
Wed Apr 06, 2011 8:38 am
if you edit scripts in console, then hi-lighting should work. If you start to have discolouration try to press F5 to refresh, if that does not help, you have error in script you are writing.
AnRkey
Wed Apr 06, 2011 10:52 am
Shweet, thats perfect!
For anyone else, do this in console to edit your scripts with syntax hi-lighting on.
/system script print brief ; # gives a list of scripts that can be edited
/system script edit "name of script here" source ; # edit a script
Thanks again MT guys!
R 8)
MTCNA
Users browsing this forum: No registered users and 16 guests
