alfagius
Solution: Automatically clean expired User-Manager accounts
Fri Jun 03, 2011 2:05 pm
Finally managed to code it, after a couple of sleepless nights!
I'm sure many people will find this useful, as I've seen quite some requests for this "missing feature".
The problem: User-Manager has no automated way to delete accounts which have gone past their 'credit-till-time' date. In a busy environment such as mine (two Hotels), where 100's of accounts are constantly being generated, the user database can grow to biblical proportions in a short time, since old accounts are never cleaned away.
The solution: What I wanted was something that cycles through all the accounts, compares their 'credit-till-time' date with today's date. If any of them has a date lesser than today, it's deleted. After a few days of tinkering, I have managed to code it.
For clarity's sake, I have made it in a way that if you run it manually through console, you will see the operations in progress and display a summary at the end. If you run it through WinBox, it will only display the final summary and push it to log.
Here it goes. Comments and / or feedback appreciated, as this is the first script that I have ever shared.
NB: Read the included notes!!
# Date: 		03/06/2011
# Revised:		22/02/2013
# Author: 		Alfredo Agius
# File:			cleanUserManager
# Tested on: 	RouterOS version 3.xx
# Description: 	Deletes Mikrotik User-Manager accounts whos credit-till-time is less than today's date.
#				Accounts which are not yet activated are skipped.
#				A summary of all accounts skipped, deleted and kept is displayed in the end of the cycle to
#				console screen and to log.
# Notes:		This script can be run either from WinBox or from console.
#				-- If console is used, all processing details will be shown, and a summary of operations in the end.
#				-- If WinBox is used, all processing details will be HIDDEN, and a summary of operations will be
#				   sent to log.
# Use:			In Winbox, go to System > Script, create a new script, name it cleanUserManager and paste
#				this whole document in it. Click Apply and OK.
# Syntax:		To run the script, from terminal enter "/system script run cleanUserManager" without quotes.
:if ([/system ntp client get status]="synchronized") do={
	:global iterator 0
	:global deleted 0
	:global skipped 0
	:global kept 0
	/tool user-manager user print brief without-paging
	:global counter [/tool user-manager user print count-only]
	:do {
		:local thisDate
		:local thisYear
		:local thisDay
		:local thisMonth
		:local thisCredit
		:local creditYear
		:local creditDay
		:local creditMonth
		:local creditName
		:set thisDate [/system clock get date]
		:set thisYear [:pick $thisDate 7 11]
		:set thisDay [:pick $thisDate 4 6]
		:set thisMonth [:pick $thisDate 0 3]
		:if ($thisMonth="jan") do { :set thisMonth "01"}
		:if ($thisMonth="feb") do { :set thisMonth "02"}
		:if ($thisMonth="mar") do { :set thisMonth "03"}
		:if ($thisMonth="apr") do { :set thisMonth "04"}
		:if ($thisMonth="may") do { :set thisMonth "05"}
		:if ($thisMonth="jun") do { :set thisMonth "06"}
		:if ($thisMonth="jul") do { :set thisMonth "07"}
		:if ($thisMonth="aug") do { :set thisMonth "08"}
		:if ($thisMonth="sep") do { :set thisMonth "09"}
		:if ($thisMonth="oct") do { :set thisMonth "10"}
		:if ($thisMonth="nov") do { :set thisMonth "11"}
		:if ($thisMonth="dec") do { :set thisMonth "12"}
		:local thisCredit [/tool user-manager user get $iterator credit-till-time]
		:set creditYear [:pick $thisCredit 7 11]
		:set creditDay [:pick $thisCredit 4 6]
		:set creditMonth [:pick $thisCredit 0 3]
		:set creditName [/tool user-manager user get $iterator name]
		:if ($creditMonth="jan") do { :set creditMonth "01"}
		:if ($creditMonth="feb") do { :set creditMonth "02"}
		:if ($creditMonth="mar") do { :set creditMonth "03"}
		:if ($creditMonth="apr") do { :set creditMonth "04"}
		:if ($creditMonth="may") do { :set creditMonth "05"}
		:if ($creditMonth="jun") do { :set creditMonth "06"}
		:if ($creditMonth="jul") do { :set creditMonth "07"}
		:if ($creditMonth="aug") do { :set creditMonth "08"}
		:if ($creditMonth="sep") do { :set creditMonth "09"}
		:if ($creditMonth="oct") do { :set creditMonth "10"}
		:if ($creditMonth="nov") do { :set creditMonth "11"}
		:if ($creditMonth="dec") do { :set creditMonth "12"}
		:if ([:len $thisCredit]!=0) do {
			:if ($creditYear>$thisYear) do {
				:put {"Kept username ".$creditName." which expires on ".$thisCredit }; :set kept ($kept+1)} else {:if ($creditYear<$thisYear) do {
				/tool user-manager user remove $creditName; :put {"Deleted username ". $creditName . " which expired on " . $thisCredit}; :set deleted ($deleted+1)} else {:if ($creditMonth>$thisMonth) do {
						:put {"Kept username " . $creditName . " which expires on " . $thisCredit}; :set kept ($kept+1)} else {:if ($creditMonth<$thisMonth) do {
							/tool user-manager user remove $creditName; :put {"Deleted username ". $creditName . " which expired on " . $thisCredit}; :set deleted ($deleted+1)} else {:if ($creditDay>=$thisDay) do {
								:put {"Kept username " . $creditName . " which expires on " . $thisCredit}; :set kept ($kept +1)} else {/tool user-manager user remove $creditName; :put {"Deleted username ". $creditName . " which expired on " . $thisCredit}; :set deleted ($deleted+1)}
		} else {:put {"Username ". $creditName . " is not yet activated. Skipping ..."}; :set skipped ($skipped+1)}
		:set iterator ($iterator+1)} while=($iterator!=$counter)
	:put {"\n\n\r==============================\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t"}
	:put {"Records processed: \t" . $counter}
	:put {"\n\rDeleted usernames: \t" . $deleted}
	:put {"Skipped usernames: \t" . $skipped}
	:put {"Kept usernames:\t\t" . $kept}
	:put {"\n\r==============================\n\r"}
	:log info ("\n\r==============================\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t")
	:log info ("Records processed: \t" . $counter)
	:log info ("\n\rDeleted usernames: \t" . $deleted)
	:log info ("Skipped usernames: \t" . $skipped)
	:log info ("Kept usernames: \t\t" . $kept)
	:log info ("\n\r==============================\n\r")
#END OF FILE
mps01k
Re: Solution: Automatically clean expired User-Manager accou
Tue Jun 07, 2011 8:31 am
thanks i needed this
setting up small WISP in Honduras over Satelite connections
JP_Wireless
Thu Jun 16, 2011 10:33 pm
This script really looks great! I am going to test it to night on version 4.17, You have done great job in deed from the look of it.
JP Wireless:::
One Stop ICT, Alternative Power & Electronics Securities Solutions Provider!
Tel: +2348098798779, +2348055353151
http://www.jpwireless.net: Email: info[at]jpwireless.net
36, Diya Road, Gbagada, Lagos - Nigeria.
reverged
Fri Jun 17, 2011 1:09 am
Nice job! And useful as well.
I just tried to use this on v5.4 and the user credit-xx functions are gone. ?
alfagius
Fri Jun 17, 2011 8:50 am
Thanks for the comments.
I have only tested it on version 3.xx, so I have no idea what changes were done to the user-manager in version 5.
I'll try to install version 5 on a spare Mikrotik when I have a free moment and have a peek at it, however I wouldn't hold my breath as my hands are pretty full right now!
JP_Wireless
Sat Jun 18, 2011 2:57 pm
Nice script! it Works perfect with v4.17, 8)
JP Wireless:::
petrn
Sat Jun 18, 2011 6:20 pm
# Important:	!! MAKE SURE THAT YOUR CLOCK DATE IS SET CORRECTLY, AS THIS SCRIPT USES IT AS REFERENCE !!
# END OF FILE
I think much safer that warning in comment is:
:if ([/system ntp client get status]="synchronized") do={"original script here"}
Everybody not only ISP,WISP should sync their clock.
Petr
boomdv
Sun Jul 24, 2011 8:40 pm
Is script is make system time sync first before do anything ?
Pls forgive my stupid question. I am a newbie.
Thank.
alfagius
Sun Jul 24, 2011 8:49 pm
No. Time syncing is something that you have to do yourself with an NTP time server.
boomdv
Sun Jul 24, 2011 9:25 pm
If i want system time sync first after reboot router and don't do anything if sync time is not. What should i do ?
Because I have a problem that some user login after RB reboot and the ntp time is not sync. Pls suggest to me.
Thank you.
alfagius
Mon Jul 25, 2011 9:32 am
trevorlc1234
Tue Aug 30, 2011 8:37 pm
Anyway to adjust this script so that it will clear out accounts that expired a month ago and not just today. Some users let their account expire then the next day fill it up again. Want to clean out old accounts that haven't been used for a month? Any pointers would be great as I'm not the best at scripting.
alfagius
Tue Aug 30, 2011 9:35 pm
Not sure if I understood what you mean.
This script deletes any account whose expiry date is before today's date. Being yesterday, a month, or a year ago does not matter.
This script in a nutshell is: if expiry_date < today, then delete. Else skip.
trevorlc1234
Tue Aug 30, 2011 9:43 pm
I see. What I was looking for is to limit that.
Example, normally a user would buy time on the hotspot, for say 1 month. They use 1 month and it expires, the script is running daily, when it finds this expired user it wipe out the expired account, but they may want to log back in and refill it the next day. So now they need to recreate their account. It would be good to be able to give it a window and delete only accounts that have been expired for 30+ days.
If the script looked for accounts with 30 days after the expiry date, then removed only those that have been expired for a month, this would be good for those users that let their accounts expire, but then top them up a few days later.
alfagius
Tue Aug 30, 2011 9:54 pm
I guess the simplest and crudest way around it, is to +1 on the variable named creditMonth, unless it's 12 (December) where it should change it to 1 (January).
That way you'll be offsetting the expiry that it's checking my 1 month.
trevorlc1234
Tue Aug 30, 2011 10:59 pm
Thanks I will play around with it and give that a shot!
alfagius
Tue Aug 30, 2011 11:21 pm
Don't forget to +1 the year too if you switch from December to January :D
trevorlc1234
Tue Aug 30, 2011 11:42 pm
thx!
botanik
Tue Oct 18, 2011 12:00 pm
Hello!
I have this error when trying to run your script :(
[admin@MikroTik] > /system script run cleanUserManager
Flags: X - disabled, A - active, I - incomplete
# NAME LOCATION IP-ADDRESS UPTIME-USED
0 test 3m23s
1
interrupted
input does not match any value of value-name
alfagius
Tue Oct 18, 2011 12:40 pm
Is the username "test" created in user-manager, or hotspot?
botanik
Tue Oct 18, 2011 2:12 pm
User "test" created in userman.
alfagius
Tue Oct 18, 2011 2:54 pm
Probably, since you're creating the username manually, you don't have a credit-till-time value.
It's what the script is designed to parse, check and delete, so if it doesn't find the value, it errors and aborts.
Try creating a username using its automated batch generator, and making sure you have a validity period.
kembiet
Sat Dec 17, 2011 12:05 pm
Really really Helpful :D
thz
usmany
Fri Jun 01, 2012 5:48 pm
If i may ask please, where do you write or paste the code to?
Run the code /
or
just copy and past in /script
Thank you
When the world turn back on you, you turn your back on the world...
alfagius
Fri Jun 01, 2012 5:52 pm
Due to how the variables are called, you have to put it in a script, and run the script itself.
It also handy to have in a script, as I run it automatically every night at 3am and cleans itself up.
usmany
Fri Jun 01, 2012 6:00 pm
Thank you so much, i will try it as well.
alfagius
Fri Jun 01, 2012 6:03 pm
Please read the notes at the top of the file thoroughly, as having the right date and time is VERY important.
raennik
Wed Aug 08, 2012 1:38 pm
Could you help doing the same thing but instead have it delete the account once it reaches a certain age?
Shevron
Fri Aug 10, 2012 10:51 am
I guess you could, but you'd probably be better off rewriting the whole thing from scratch, rather than modding this one, as this was written with a completely different purpose in mind, so the date comparison routines would be completely different.
raennik
Fri Aug 10, 2012 6:59 pm
Thx, I'll faff around and post new topic on it.
manggatal
Thu Nov 08, 2012 12:19 pm
thanks for this scripts i ll try it bro..!!
Gunawan Nasution
Jasa Setting Mikrotik Indonesia
http://mandailingnatal.com
+6285763810001
leemans
Tue Nov 27, 2012 4:32 pm
alfagius,
How to change the 'Automatically clean expired User-Manager accounts' script on this way that only the users accounts will be deleted which meet the following requirements:
last-seen is < today
and Uptime-Used>0
and Till-time=Unknown
and Total-Time-Left=""
and Time-Left=""
Thanks in advance.
Patrick
murray654
Wed Dec 19, 2012 11:49 am
Hi
I used this script before, but now it just says:
1419 xh9p6u
1420
interrupted
input does not match any value of value-name"
My routeros version is 5.7 on rb750
Any way to fix this? Any other solutions?
Oliviershoek Consulting
Safely Navigating your IT Storms
alfagius
Fri Feb 22, 2013 3:36 pm
Added a small update to the original code that queries the status of the NTP client.
It only runs if NTP reports back as "syncronized", therefore avoiding any disasters due to an unset system date.
oldsnake
Sun Feb 24, 2013 6:01 am
can i use in user-man v5.17. ?
PPJ
Sun Mar 24, 2013 10:07 am
In a process of learning and working I found this script. It runs all the way through ONLY when I remark (#) out this line:
From this I think (guess) that the variable "credit-till-time" can not be found or does not exist. The router I am using for test purposes is a RB750 with the latest ROS. ( I use a backup from a live userman installation to test scripts (and RB configs))
I have done a fair amount of looking but can not find a list or document or manual that give all the variables that are available for userman.
I must be looking in the wrong places because if you could find and know about this variable (and others) it must be somewhere??
Can anyone one help me on this one please.
Never say, or even think, that you are going to do it quickly on the computer........
alfagius
Sun Mar 24, 2013 10:12 am
I'll have to look into that on the new versions. I will give it a good peek tomorrow at work.
Credit-till-time did exist in userman 3.xx, and it held the date of when an account was bound to expire according to the length of time assigned to it, and it's the foundation on which the whole script is based upon.
Will be bummed if it got removed.
Maybe they changed the name or something. I'll test it let you know :)
PPJ
Tue Mar 26, 2013 10:25 am
Thanks alfagius!! :)
If possible, can someone point me to a document listing the variables available for usermanager.
josemari
Fri Apr 12, 2013 1:59 pm
Has anyone tested on v5.24?
Thanks.
alfagius
Thu Apr 18, 2013 6:24 pm
Tested it. Does not work.
The credit-till-time variable has been removed, much to my annoyance. It was the concept on which this whole script was built.
It's totally useless in 5.xx, and I've been trying to find a workaround. Haven't succeeded so far.
In fact I'm considering going back to 3.xx to get all my functionalities back. This isn't the only thing I'm finding utterly frustrating in 5.xx
josemari
Fri Apr 19, 2013 10:13 am
Alfagius, thank you very much for all your time and work, and never give up.
Josemari.
aleprolit
Thu Aug 01, 2013 3:45 pm
This script work with RouterOS version 6.1
# Date:       03/06/2011
# Revised:      01/08/2013
# Revised by Alexander Prozorov - adaptation for RouterOS version 6.xx
# Tested on:    RouterOS version 6.1
# Description:    Deletes Mikrotik User-Manager accounts whos not active more or equal 3 month.
#            Accounts which have valid profile are skipped.
# Notes:
#				This script work if NTP package is installed.
#				This script can be run either from WinBox or from console.
#               sent to log.
   :global iterator 0
   :global deleted 0
   :global skipped 0
   :global kept 0
   :do {
      :local thisDate
      :local thisYear
      :local thisDay
      :local thisMonth
      :local thisSeen
      :local thisProfile
      :local thisOwner
      :local thisCredit
      :local creditYear
      :local creditDay
      :local creditMonth
      :local expireMonth
      :local creditName
      :local thisSeen [/tool user-manager user get $iterator last-seen]
      :local thisProfile [/tool user-manager user get $iterator actual-profile]
      :local thisOwner [/tool user-manager user get $iterator customer]
      :if ([:len $thisProfile]!=0) do {
      :put {"Username ". $creditName . " Have valid profile:". $thisProfile . " Skipping ..."};
      :set skipped ($skipped+1) } else {
      :if ([$thisSeen]!= "never") do {
      :set creditYear [:pick $thisSeen 7 11]
      :set creditDay [:pick $thisSeen 4 6]
      :set creditMonth [:pick $thisSeen 0 3]
      :if ($creditMonth="jan") do { :set creditMonth "04";:set expireMonth "apr"}
      :if ($creditMonth="feb") do { :set creditMonth "05";:set expireMonth "may"}
      :if ($creditMonth="mar") do { :set creditMonth "06";:set expireMonth "jun"}
      :if ($creditMonth="apr") do { :set creditMonth "07";:set expireMonth "jul"}
      :if ($creditMonth="may") do { :set creditMonth "08";:set expireMonth "aug"}
      :if ($creditMonth="jun") do { :set creditMonth "09";:set expireMonth "sep"}
      :if ($creditMonth="jul") do { :set creditMonth "10";:set expireMonth "oct"}
      :if ($creditMonth="aug") do { :set creditMonth "11";:set expireMonth "nov"}
      :if ($creditMonth="sep") do { :set creditMonth "12";:set expireMonth "dec"}
      :if ($creditMonth="oct") do { :set creditMonth "01";:set expireMonth "jan";:set creditYear ($creditYear+1)}
      :if ($creditMonth="nov") do { :set creditMonth "02";:set expireMonth "feb";:set creditYear ($creditYear+1)}
      :if ($creditMonth="dec") do { :set creditMonth "03";:set expireMonth "mar";:set creditYear ($creditYear+1)}
	  :set thisCredit ($expireMonth ."/". $creditDay . "/". $creditYear)
      :set kept ($kept+1) } else {
      :set deleted ($deleted+1) } else {
      :if ($creditMonth<($thisMonth)) do {
       :set kept ($kept +1) }  else {
       }  else {
   :put {"\n\n\r________________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t"}
   :put {"\n\r__________________________________\n\r"}
   :log info ("\n\r_________________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t")
   :log info ("\n\r_________________________________\n\r")
#END OF FILE
alfagius
Thu Aug 01, 2013 3:50 pm
Oh ho!
Thank you, I'll give it a spin!
aleprolit
Thu Aug 01, 2013 7:58 pm
and next revision:
It remove users, which registered thru PayPal, but not buy any profile, every time loaded this script and registered users never active after 1 month.
# Date:       03/06/2011
# Script version (V.2)
# Tested on:    RouterOS version 6.2
#            Accounts which are not yet activated are skipped but removed if not activated 1 month.
#            You must to add to account comment creation date by hand or by script.
# Notes:
#               sent to log.
   :global iterator 0
   :global deleted 0
   :global skipped 0
   :global kept 0
   :do {
      :local thisDate
      :local thisYear
      :local thisDay
      :local thisMonth
      :local thisSeen
      :local thisProfile
      :local thisOwner
      :local thisCredit
      :local creditYear
      :local creditDay
      :local creditMonth
      :local expireMonth
     :local comment
      :local creditName
     :set comment [/tool user-manager user get $iterator comment]
      :if ($thisSeen = "never") do {
	        :set creditYear [:pick $comment 7 11]
       :set creditDay [:pick $comment 4 6]
       :set creditMonth [:pick $comment 0 3]
#2)
      :if ($creditMonth="jan") do { :set creditMonth "02";:set expireMonth "feb"}
       :if ($creditMonth="feb") do { :set creditMonth "03";:set expireMonth "mar"}
       :if ($creditMonth="mar") do { :set creditMonth "04";:set expireMonth "apr"}
       :if ($creditMonth="apr") do { :set creditMonth "05";:set expireMonth "may"}
       :if ($creditMonth="may") do { :set creditMonth "06";:set expireMonth "jun"}
       :if ($creditMonth="jun") do { :set creditMonth "07";:set expireMonth "jul"}
       :if ($creditMonth="jul") do { :set creditMonth "08";:set expireMonth "aug"}
       :if ($creditMonth="aug") do { :set creditMonth "09";:set expireMonth "sep"}
       :if ($creditMonth="sep") do { :set creditMonth "10";:set expireMonth "oct"}
       :if ($creditMonth="oct") do { :set creditMonth "11";:set expireMonth "nov"}
       :if ($creditMonth="nov") do { :set creditMonth "12";:set expireMonth "dec"}
       :if ($creditMonth="dec") do { :set creditMonth "03";:set expireMonth "jan";:set creditYear ($creditYear+1)}
#2)
      :put {"Username ". $creditName . " is not yet activated and expires on ".$thisCredit . " Skipping ..."};
       :set skipped ($skipped+1)} else {
	   }  else {
#1)
#1)
   :put {"\n\r_________________________________\n\r"}
   :log info ("\n\r________________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t")
   :log info ("\n\r________________________________\n\r")
#END OF FILE
You can edit path marked 1) to change how long account saved in UM DB
and path marked 2) to change how long never active account saved in UM DB.
Load this script from scheduler:
/system scheduler
add interval=1d name=cleanUserManager on-event=cleanUserManager policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api start-date=\
    dec/08/2010 start-time=02:00:00
Script example for account add with adding date to comment:
(It completed for Lithuania - you can use Google to translate)
<?php
namespace PEAR2\Net\RouterOS;
include_once '../../src/php/PEAR2/Autoload.php';include '../param.common.php';
//../include_once 'PEAR2_Net_RouterOS-1.0.0b3.phar';
<title>Priseregistravimas.</title>
<html>
<head>
<title>Priseregistravimas</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv='Content-Language' content='lt' />
<meta http-equiv='content-style-type' content='text/css' />
<link rel="stylesheet" type="text/css" href="../css.css">
</head>
<?php
if(trim($_POST['email'])=='') {
die("Neįrašėte emailą! <br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}&location={$_POST['location']}'> atgal.<br /></a>");
else {
echo "";
if(trim($_POST['name'])=='Jūsų abonento vardas.') {
die("Neįrašėte savo vartotojo vardą! <br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}&location={$_POST['location']}'> atgal.<br /></a>");
else {
echo "";
if(trim($_POST['name'])=='') {
else {
echo "";
if(trim($_POST['password'])=='') {
die("Neįrašėte savo slaptažodį! <br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}&location={$_POST['location']}'> atgal.<br /></a>");
else {
echo "";
if(trim($_POST['password1'])=='') {
die("Neįrašėte pakartotinai slaptažodį! <br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}&location={$_POST['location']}'> atgal.<br /></a>");
else {
echo "";
if(trim($_POST['phone'])=='') {
die("Neįrašėte savo telefono numerį! <br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}&location={$_POST['location']}'> atgal.<br /></a>");
else {
echo "";
if(trim($_POST['phone'])=='Jūsų telefono numeris.') {
else {
echo "";
include 'check-phone.php';
$txt1 = 'added by ';
$first = $_POST['first-name'];
$txt2 = ' ';
$last = $_POST['last-name'];
$txt3 = ' !';
   if ('' === $_POST['first-name'])
    $comment = $txt2.'added by User!';
    } else {
	$comment = $txt2.$txt1.$first.$txt2.$last.$txt3;
if (isset($_POST['password']) && isset($_POST['password1'])) {
    if ($_POST['password'] !== $_POST['password1']) {
    echo "Slaptažodžiai nesutampa.<br>";
    } else {
$client = new Client($host,$admin,$pass);
$printRequest = new Request('/tool user-manager user print');
$printRequest->setArgument('.proplist', '.id');
$printRequest->setQuery(Query::where('name', $_POST['name']));
$userId = $client->sendSync($printRequest)->getArgument('.id');
    if (null !== $userId ) {
    echo "Vartotojas {$_POST['name']} jau egzistuoja.<br>";
    } else {
    $printRequest->setQuery(Query::where('phone', $_POST['phone']));
    $userPh = $client->sendSync($printRequest)->getArgument('.id');
    if (null !== $userPh ) {
    echo "Vartotojas turintis numerį {$_POST['phone']} egzistuoja.<br>";
	} else {
                  try {$printRequest = new Request('/system clock print');
					   $printRequest->setArgument('.proplist','date');
					   $date = $client->sendSync($printRequest)->getArgument('date');
					   $comment = $date.$comment;
					   $addRequest = new Request('/tool user-manager user add');
                       $addRequest->setArgument('customer',gsm);
                       $addRequest->setArgument('name',$_POST['name']);
					   $addRequest->setArgument('first-name',$_POST['first-name']);
					   $addRequest->setArgument('last-name',$_POST['last-name']);
					   $addRequest->setArgument('location',$_POST['location']);
                       $addRequest->setArgument('email',$_POST['email']);
                       $addRequest->setArgument('password',$_POST['password']);
                       $addRequest->setArgument('phone',$_POST['phone']);
                       $addRequest->setArgument('disabled',no);
                       $addRequest->setArgument('comment', $comment);
                       $addRequest->setArgument('shared-users',1);
                    if ($client->sendSync($addRequest)->getType() !== Response::TYPE_FINAL) {
                       echo "Error when added  '{$_POST['name']}'. Neteisingas e-mail formatas.<br>";
                       } else {
                       echo "Comment: '{$comment}'. Vartotojas'{$_POST['name']}' sėkmingai sukurtas!.";
					   echo "<br />Aktivuoti paslaugą:<a href='../../payment/plan.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&email={$_POST['email']}&phone={$_POST['phone']}'> Spausk čia!</a>";
                       } catch(Exception $e) {
                       echo $e;
echo "<br />Grįžti<a href='index.php?name={$_POST['name']}&loglink={$_POST['linkloginonly']}&first-name={$_POST['first-name']}&last-name={$_POST['last-name']}&location={$_POST['location']}&email={$_POST['email']}&phone={$_POST['phone']}&password={$_POST['password']}'> atgal</a>";
You can see my interface for user add, payment and etc. here Free Net (Lithuanian)
If You have any questions, be free to ask.
alfagius
Thu Aug 01, 2013 8:02 pm
Blimey ... you really took my basic script idea to the next level!
aleprolit
Thu Aug 01, 2013 8:11 pm
Спасибо! Будет приятно если это будет кому нибудь полезно...
Thank you! It will be nice if it would be useful to someone ...
Abdock
Sat Aug 03, 2013 7:43 pm
I tried to run on a 5.25, and got the below error,
jdg
Tue Aug 06, 2013 5:09 pm
Very, very nice script! :D
Thank you!
If there were such a script for logs and session of UM, who can delete only old - 2 or 3 monts entries in the log and session...life would become better :)
aleprolit
Sun Aug 11, 2013 10:49 pm
To Abdock !
It may be. Script in MT 5.25 and 6.xx have differences.
For example:
I do this script at MT 6.1 and after update to MT 6.2 it stop work, and I must to edit script.
Try to do:
from console run /sys script print
and you can see where is error.
aleprolit
Mon Aug 12, 2013 1:39 am
To jdg .
I think it's possible to include this function to this script or write separate script.
Examples:
1)Script to cleanup logs which oldest than 3 month:
# Date:       03/06/2011
# File:         cleanUserLogs
# Description:    Deletes Mikrotik User-Manager user logs which age more than 3 month.
#            A summary of all logs deleted and kept is displayed in the end of the cycle to
# Notes:
#               sent to log.
# Use:         In Winbox, go to System > Script, create a new script, name it cleanUserLogs and paste
# Syntax:      To run the script, from terminal enter "/system script run cleanUserLogs" without quotes.
   :global deletedL 0
   :global keptL 0
   :global iteratorL 0
   :local thisDate
   :local thisYear
   :local thisDay
   :local thisMonth
   :local thisLog
   :local logSeen
   :local logYear
   :local logDay
   :local logMonth
   :local expireMonth
   /tool user-manager log print without-paging
   :global counterL [/tool user-manager log print count-only]
   :foreach i in=[/tool user-manager log find] do {
      :local logSeen [/tool user-manager log get $iteratorL time]
      :set logYear [:pick $logSeen 7 11]
      :set logDay [:pick $logSeen 4 6]
      :set logMonth [:pick $logSeen 0 3]
      :if ($logMonth="jan") do { :set logMonth "04";:set expireMonth "apr"}
      :if ($logMonth="feb") do { :set logMonth "05";:set expireMonth "may"}
      :if ($logMonth="mar") do { :set logMonth "06";:set expireMonth "jun"}
      :if ($logMonth="apr") do { :set logMonth "07";:set expireMonth "jul"}
      :if ($logMonth="may") do { :set logMonth "08";:set expireMonth "aug"}
      :if ($logMonth="jun") do { :set logMonth "09";:set expireMonth "sep"}
      :if ($logMonth="jul") do { :set logMonth "10";:set expireMonth "oct"}
      :if ($logMonth="aug") do { :set logMonth "11";:set expireMonth "nov"}
      :if ($logMonth="sep") do { :set logMonth "12";:set expireMonth "dec"}
      :if ($logMonth="oct") do { :set logMonth "01";:set expireMonth "jan";:set logYear ($logYear+1)}
      :if ($logMonth="nov") do { :set logMonth "02";:set expireMonth "feb";:set logYear ($logYear+1)}
      :if ($logMonth="dec") do { :set logMonth "03";:set expireMonth "mar";:set logYear ($logYear+1)}
	  :set thisLog ($expireMonth ."/". $logDay . "/". $logYear)
      :if ($logYear>$thisYear) do {
      :put {"Kept log ".$iteratorL." which expires on ".$thisLog };
      :set keptL ($keptL+1) } else {
      :if ($logYear<$thisYear) do {
      /tool user-manager log remove $i;
      :put {"Deleted log ".$iteratorL. " which expired on ".$thisLog};
      :set deletedL ($deletedL+1) } else {
      :if ($logMonth>$thisMonth) do {
      :put {"Kept log " .$iteratorL. " which expires on ".$thisLog};
      :if ($logMonth<($thisMonth)) do {
      :if ($logDay>=$thisDay) do {
      :set keptL ($keptL +1) }  else {
	  :set iteratorL ($iteratorL+1);
   :put {"\n\n\r____________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t"}
   :put {"Records processed: \t" . $counterL}
   :put {"\n\rDeleted logs: \t" . $deletedL}
   :put {"Kept logs:\t\t" . $keptL}
   :put {"\n\r______________________________\n\r"}
   :log info ("\n\r_______________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t")
   :log info ("Records processed: \t" . $counterL)
   :log info ("\n\rDeleted logs: \t" . $deletedL)
   :log info ("Kept logs: \t\t" . $keptL)
   :log info ("\n\r_______________________________\n\r")
2)Same script to cleanup sessions which oldest than 3 month:
# Date:       03/06/2011
# File:         cleanUserSession
# Description:    Deletes from Mikrotik User-Manager sessions which age more than 3 month.
#            A summary of all sessions deleted and kept is displayed in the end of the cycle to
# Notes:
#               sent to log.
# Use:         In Winbox, go to System > Script, create a new script, name it cleanUserSession and paste
# Syntax:      To run the script, from terminal enter "/system script run cleanUserSession" without quotes.
   :global deletedS 0
   :global keptS 0
   :global iteratorS 0
   :local thisDate
   :local thisYear
   :local thisDay
   :local thisMonth
   :local thisLog
   :local logSeen
   :local logYear
   :local logDay
   :local logMonth
   :local expireMonth
   /tool user-manager session print without-paging
   :global counterS [/tool user-manager session print count-only]
   :foreach i in=[/tool user-manager session find] do {
      :local logSeen [/tool user-manager session get $iteratorS till-time]
      :put {"Kept session ".$iteratorS." which expires on ".$thisLog };
      :set keptS ($keptS+1) } else {
      /tool user-manager session remove $i;
      :put {"Deleted session ".$iteratorS. " which expired on ".$thisLog};
      :set deletedS ($deletedS+1) } else {
      :put {"Kept session " .$iteratorS. " which expires on ".$thisLog};
      :set keptS ($keptS +1) }  else {
	  :set iteratorS ($iteratorS+1);
   :put {"Records processed: \t" . $counterS}
   :put {"\n\rDeleted sessions: \t" . $deletedS}
   :put {"Kept sessions:\t\t" . $keptS}
   :log info ("Records processed: \t" . $counterS)
   :log info ("\n\rDeleted sessions: \t" . $deletedS)
   :log info ("Kept sessions: \t\t" . $keptS)
aleprolit
Wed Aug 14, 2013 11:48 am
And script for UM DB backup to external FTP server:
# automated Um  backup  to External FTP
#File name:Um-FTP-Backup
# Get time
:local ts [/system clock get time]
:set ts ([:pick $ts 0 2].[:pick $ts 3 5].[:pick $ts 6 8])
# Get Date
:local ds [/system clock get date]
:local month
   :set month [:pick $ds 0 3]
   :if ($month="jan") do { :set month "01"}
   :if ($month="feb") do { :set month "02"}
   :if ($month="mar") do { :set month "03"}
   :if ($month="apr") do { :set month "04"}
   :if ($month="may") do { :set month "05"}
   :if ($month="jun") do { :set month "06"}
   :if ($month="jul") do { :set month "07"}
   :if ($month="aug") do { :set month "08"}
   :if ($month="sep") do { :set month "09"}
   :if ($month="oct") do { :set month "10"}
   :if ($month="nov") do { :set month "11"}
   :if ($month="dec") do { :set month "12"}
:set ds ([:pick $ds 7 11]."_".$month."_".[:pick $ds 4 6])
# This line to generate the file name for System backup - file name will be User_Manager- ServerName? - Date? - Time?
#:local fname ("/_User_Manager_".[/system identity get name]."_".$ds."_".$ts.".umb")
:local fname ("/_User_Manager_".$ds."_".$ts.".umb")
/tool user-manager database save name=$fname
:log info message=UmBackupFinished;
# Upload the System Backup to External FTP - change address to your ftp server + user + pass+upload_path
/tool fetch address="192.168.x.y" user="user" password="password" mode=ftp src-path="$fname" dst-path="upload_path/$fname" upload=yes
:delay 60s;
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "_User_Manager_"]]!="nil") do={/file remove $i}}
:log info message=SystemBackup-TempRemoved;
:log info message=SystemBackup-Finished;
You must add schedule for all scripts:
/system scheduler
add interval=1d name=Um-FTP-Backup on-event=Um-FTP-Backup policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    start-date=dec/08/2010 start-time=01:00:00
    start-date=dec/08/2010 start-time=02:00:00
add interval=1d name=cleanUserLogs on-event=cleanUserLogs policy=\
    start-date=dec/08/2010 start-time=02:30:00
add interval=1d name=cleanUserSession on-event=cleanUserSession policy=\
    start-date=dec/08/2010 start-time=03:00:00
jdg
Fri Aug 16, 2013 5:18 pm
Thank you! I'll try it and then post!
alfagius
Mon Aug 19, 2013 10:44 am
Makes me very happy to have started this, seeing how it's evolving :D
It was so much needed in UM!
Thank to all those who are contributing, and giving feedback.
vipe
Tue Sep 24, 2013 8:12 am
:D
this Script very good!
Fleury
Sun Nov 10, 2013 11:21 pm
Did someone get a script working with 5.4?
jdg
Sun Dec 29, 2013 8:50 pm
I used script above a while, but for several reasons I have to use this script:
:global deleted 0;
:global skipped 0;
:global counter 0;
:log info ("\n\r_________________________________\n\n\rCleaning users ready!\n\n\rPerformed these operations:")
/tool user-manager user print brief without-paging;
:foreach i in=[/tool user-manager user find] do={
:local thisProfile [/tool user-manager user get $i actual-profile];
:local creditName [/tool user-manager user get $i name];
:if ([:len $thisProfile]!=0) do={
:set skipped ($skipped+1)} else={
:put {"Delete username: \t" . $creditName}
:log info ("Delete username: \t" . $creditName)
:set deleted ($deleted+1)};
:set counter ($counter+1);
:put {"\n\n\r________________________________\n\n\rCleaning ready!\n\n\rPerformed these operations:\n\r\t"};
:put {"Records processed: \t" . $counter};
:put {"\n\rDeleted usernames: \t" . $deleted};
:put {"Skipped usernames: \t" . $skipped};
:put {"\n\r__________________________________\n\r"};
:log info ("Deleted usernames: \t" . $deleted)
:log info ("_________________________________\n\r")
It's work good, but sometime fails to delete expires users from UM DB. In the log is the line, for example:
"Delete username: xyz"
but realy user xyz and all expires users after xyz is not deleted from UM DB.
The solution is to manually delete users from userman web page tool. Then the script works normally until any strange user who is not deleted from the database.
Any help, please?
jdg
Fri Jan 03, 2014 9:43 am
Any help from mikrotik support team, please!
jdg
Thu Feb 20, 2014 1:29 pm
Finaly this script working for me:
:global iterator 0
:global deleted 0;
:global skipped 0;
:do {
:local creditName [/tool user-manager user get $iterator name]
/tool user-manager user remove $iterator;
aonallah
Sun Sep 21, 2014 9:35 pm
# Date:       03/06/2011
# Notes:
#               sent to log.
   :global iterator 0
   :global deleted 0
   :global skipped 0
   :global kept 0
   :do {
      :local thisDate
      :local thisYear
      :local thisDay
      :local thisMonth
      :local thisSeen
      :local thisProfile
      :local thisOwner
      :local thisCredit
      :local creditYear
      :local creditDay
      :local creditMonth
      :local expireMonth
      :local creditName
       }  else {
#END OF FILE
my mikrotik on pc ... v 5.20 x86
I used scripts above, but no any result and no error!!!?????!!!!
please!
Jaggl
Sun Dec 28, 2014 7:27 pm
To jdg .
Examples:
# Date:       03/06/2011
# Notes:
#               sent to log.
   :global deletedL 0
   :global keptL 0
   :global iteratorL 0
   :local thisDate
   :local thisYear
   :local thisDay
   :local thisMonth
   :local thisLog
   :local logSeen
   :local logYear
   :local logDay
   :local logMonth
   :local expireMonth
# Date:       03/06/2011
# Notes:
#               sent to log.
   :global deletedS 0
   :global keptS 0
   :global iteratorS 0
   :local thisDate
   :local thisYear
   :local thisDay
   :local thisMonth
   :local thisLog
   :local logSeen
   :local logYear
   :local logDay
   :local logMonth
   :local expireMonth
hello,
is it possible to delete logs and sessions older than 1 month instead of 3 months?
Mit freundlichen Grüßen / Yours sincerely
Roland Steger
+43 (0) 664 333 7393
Kontakt [AT] Hosters.at
www.Hosters.at
EA Ranked Server Partner
Pragmatic Preferred Provider
Teamspeak Authorized Hoster
hsabrey
Sat Jan 31, 2015 9:59 pm
Hello guys,
In my case UM is used to generate and manage vouchers of 1hr per day, I want to automate the deletion of used vouchers.
I'm using UM 6.20 some locations have 6.22
Sorry I'm new to this point, and appreciate your support.
alfntoosh
Re: Solution: Automatically clean expired User-Manager accounts
Sun Dec 20, 2015 9:30 am
after updated for work in new version 6.3.xx
# Date:       03/06/2011
# Revised:      20/12/2015 by Emad Alkadry #Yemen +967711505151
# Tested on:    RouterOS version 6.3.33
#EM. AD.
# Description:    Deletes Mikrotik User-Manager accounts whos not active more or equal 1 month.
# Notes:
#            This script work if cloud update time updated
#               sent to log.
if ([/ip cloud get status]="updated") do={
   :global iterator 0
   :global deleted 0
   :global skipped 0
   :global kept 0
   :do {
      :local thisDate
      :local thisYear
      :local thisDay
      :local thisMonth
      :local thisSeen
      :local thisProfile
      :local thisOwner
      :local thisCredit
      :local creditYear
      :local creditDay
      :local creditMonth
      :local expireMonth
      :local creditName
      :set $thisDate [/system clock get date]
      :set $thisYear [:pick $thisDate 7 11]
      :set $thisDay [:pick $thisDate 4 6]
      :set $thisMonth [:pick $thisDate 0 3]
:set $creditName [/tool user-manager user get $iterator username]
      :set $skipped ($skipped+1) } else {
      :set $creditYear [:pick $thisSeen 7 11]
      :set $creditDay [:pick $thisSeen 4 6]
      :set $creditMonth [:pick $thisSeen 0 3]
      :if ($creditMonth="dec") do { :set creditMonth "01";:set expireMonth "jan";:set creditYear ($creditYear+1)}
     :set $thisCredit ($expireMonth ."/". $creditDay . "/". $creditYear)
      :set $kept ($kept+1) } else {
      :set $deleted ($deleted+1) } else {
       :set $kept ($kept +1) }  else {
       }  else {
       :set $skipped ($skipped+1)}
       :set $iterator ($iterator+1)
#END OF FILE
Emad Alkadry
derr12
Fri Jan 15, 2016 10:58 pm
Im on 6.33.3 and I ran this latest script. It doesnt seem to have any readout in the logs or terminal in winbox when executed. no errors or nothing.
How do i know if it's working or not?
alfntoosh
Sun Mar 20, 2016 12:44 am
maybe you didn't have any users expired before 1 month
Emad Alkadry
jhonnyp
Fri Aug 12, 2016 3:37 pm
Work Fine
V6.35.4
prawira
Trainer
Trainer
Fri Sep 16, 2016 11:44 am
i try the script on my RB433 with ROS 4.17 and it does not work.
the error is : input does not match any value of value-name
the script was tried from console and /system script and both give the same result.
any help will be appriciate
thank you
Paul
yerzhl
Sat Oct 29, 2016 1:59 pm
Hi alfagius,
Thanks for sharing the idea and solution. Really appreciate and helpful.
ronnel25
Tue Sep 05, 2017 3:46 pm
work fine @ 6.30.4
I have question how to delete the expire voucher after a day where can i edit the script
Thank in advance
mrdipesh1
Fri Nov 03, 2017 6:10 am
trigger
:delay 60
/system script run delete_expired
Here the trigger script waits for 60 second then calls the delete_expired script
delete_expired
:foreach i in [/ip hotspot user find] do={
:if ([/ip hotspot user get $i limit-uptime]<=[/ip hotspot user get $i uptime]) do={
/ip hotspot user remove $i;
/system script run trigger
Here delete_expired scripts checks all the users whose limit-uptime is equal or less to uptime.
If any user is found expired then it will delete them.
And after If() statement is completed it will again call trigger script. And this loop goes continuously.
To check if this code work for you or not, just simply create a test user with no limit-uptime set and run this script
or you can add a log to check
:log info "your message"
whether the script is working every seconds or not.
It works for me
ADahi
Sun Nov 26, 2017 8:49 pm
Try this Script
/tool user-manager user remove numbers=[find where !actual-profile];
Echniajaw
Sun Sep 16, 2018 2:06 am
hi
i need same kind of this usefull script but instend of removing expired User remove the users that reached total bytes limit because in my services im not using period to limit im using how much user using data as download and upload if anybody can help will be great
thanks in advance
kmznet
Tue Sep 24, 2019 9:29 am
With UM latest version, it is easy to accomplish:
Look for [Users]
[Total time left] [is] [equal to] type 0 (zero)
and click Search... voila. There the expired users list that you can remove from the menu bar command.
freemannnn
Long time Member
Long time Member
Tue Sep 24, 2019 10:35 am
Look for [Users]
the is not [Total time left] just [Time Left]
alfagius
Tue Mar 02, 2021 6:50 pm
Glad to see people are still finding it useful and still tinker with it after all these years :D
I changed job and don't tinker with MikroTiks anymore, which is a pity. I miss the little buggers.
Users browsing this forum: Baidu [Spider] and 8 guests
