angboontiong
RouterOS V5.4 cannot send mail...
Thu Sep 15, 2011 3:52 pm
Dear buddy...
may i know, how to make the send mail work?
I try with this..
/tool e-mail send from=error@mykris.net server=202.133.97.xx to=bt.ang@mykris.net
it's doesn't work.
where may goes wrong?
p/s: 202.133.97.xx is the mail server.
appreciated it.
thanks.
ang.
mrz
Re: RouterOS V5.4 cannot send mail...
Thu Sep 15, 2011 4:01 pm
enable email debug logs and check for error messages
angboontiong
Thu Sep 15, 2011 4:21 pm
Good day...
Hi..
You can see that, if the watch dog reboot the bridge, i able to received the email notification with the supout file from the bridge.
but when i test the /tool send mail, it's not working.
fewi
Thu Sep 15, 2011 4:41 pm
Look at the log debug output when it's NOT working. According to what you're showing email was sent. It's impossible to troubleshoot based on a successful attempt.
On a side note you may find it easier to just use "/log print" and copy/paste the relevant parts than to resize log windows and take screenshots. It's text, and this is a text forum. They're kind of made for one another.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Percanta
Thu Sep 22, 2011 2:12 am
it's not "server" anymore, now it is "address"
/tool e-mail send from=error@mykris.net address=202.133.97.xx to=bt.ang@mykris.net
i've had to change all of my script routers
it'd be great to know a more complete changelog......
janisk
Thu Sep 22, 2011 9:21 am
thanks, manual updated. Change came as ipv6 support was added to the tool, hence the separation of address and port, also attribute name change.
pedja
Long time Member
Long time Member
Thu Sep 22, 2011 10:53 am
They changed syntax AGAIN!?!?!?!
janisk
Thu Sep 22, 2011 1:05 pm
not again. it was so since ipv6 changes, manual was not updated since then.
Users browsing this forum: exynos5, Jotne and 24 guests
