lambert
Long time Member
Long time Member
/export without line wrap?
Fri Sep 16, 2011 1:53 am
Searching for ways to do things without "x" never works well.
I want to export items from my MikroTiks but I want to avoid having to put the continued lines back together with my scripts. I can add a subroutine to my scripts to do that for me, but it would be nice if there were an option in RouterOS which would avoid putting them in there in the first place.
If I connect with a terminal, I get lines wrapped as wide as the terminal.
If I "ssh router '/export;' > router.export.txt" I get lines wrapped for an 80 column terminal. I would hope for no wrapping when not in an active terminal.
With "ssh router -t '/export;' > router.export.txt" I get terminal width line (100 columns in this case, not wide enough for the lines I need) but I also get the escape codes which color the output.
add address=CPEPriv address-list=8MbDedicated client-id=1:0:0:0:0:0:0 \
    comment=customer1-cpe disabled=no mac-address=00:00:00:00:00:00 \
    server=ap_dhcp1
should be:
add address=CPEPriv address-list=8MbDedicated client-id=1:0:0:0:0:0:0 comment=customer1-cpe disabled=no mac-address=00:00:00:00:00:00 server=ap_dhcp1
janisk
Re: /export without line wrap?
Mon Sep 19, 2011 10:24 am
there is no way to set it in export as that gets tailored for terminal you are using. On the other hand you can try to use login options that set some auto-detected values for the terminal session.
http://wiki.mikrotik.com/wiki/Manual:Co ... in_options
set width reasonably high :)
peterd
Mon Sep 19, 2011 11:14 am
It would be nice if you could do that from winbox, as an option to set permanently
Regards
"I love it when a plan comes together."
lambert
Long time Member
Long time Member
Mon Sep 19, 2011 12:32 pm
Thanks. That should work.
Reg24
Fri Feb 03, 2017 3:54 am
This doesn't work in WinBox 3.10 and 2011UiAS-2HnD fw 6.37.4
Trying to set admin+300w, then /export file=filename
janisk
Fri Feb 03, 2017 10:37 am
output to the file is set to one constant line length and cannot be changed.
candlerb
Sun Sep 10, 2017 9:05 pm
That's not the case: if you've connected from Linux over ssh, and you drag the window narrower or wider and re-run /export, the line breaks are in a different place to match the new width.
The mechanism is described here: https://unix.stackexchange.com/question ... and-telnet
You can see the difference by setting a wide window and then comparing:
ssh -t admin@gw '/export'   # no pty, uses default line width
ssh -T admin@gw '/export'   # with pty, adjusts to line width of window
It certainly would be very nice to be able to say "don't wrap"; having variable wrapping makes it difficult to compare diffs.
candlerb
Sun Sep 10, 2017 9:08 pm
My apologies, I did not read "output to the file". I guess file wrapping is same as login with no pseudo-tty.
janisk
Tue Sep 12, 2017 11:02 am
No, output to file cannot be changed. Even with login parameters set.
strods
Tue Sep 12, 2017 11:45 am
You can run "/export terse" which will give output of configuration without line wraps.
fdaniele
Sat Mar 31, 2018 8:08 am
terse is perfect... thanks
UWtbilmC9w7jWcWAg8zB
Fri Nov 23, 2018 8:06 pm
Hi @strods when running an export with the terse option I get:
[admin@c0re] > /export terse
expected end of command (line 1 column 9)
On our other 3 routers it is working as expected. What is wrong with this one?
Users browsing this forum: No registered users and 13 guests
