richedav
Strip Linefeed/EOL from fetched file
Sat Oct 15, 2011 6:27 pm
Hi All
Just started to play with Scripting which is working well, except for the problem I have with a \n appearing on the end of the file I am pulling from a website
Its a very basic script, simply pulls a SSID down from the server , and sets the SSID on the WLAN1 interface if its different to that previously suppled ( to facilitate basic management of the hotspot service from a cloud based system)
If the server outputs 'test'
Mikrotk is reporting the said as 'test\n'
Theres no trim commands, so whats the best way to remove the EOL characters?
Many thanks
TealFrog
Re: Strip Linefeed/EOL from fetched file
Sat Nov 05, 2011 9:07 am
It may be a bit late, but actually the script I posted a day before your post does something very similar to this...
http://forum.mikrotik.com/viewtopic.php?f=9&t=55738
If you want to trim the last character, then it is just a matter of doing something like:
:put [ :pick "test\n" 0 ( [ :len "test\n" ] -1 ) ];
As another example:
:local w "test\n";
:put [ :pick $w 0 ( [ :len $w ] -1 ) ];
To get characters up to the occurrence of the end of line (newline) character:
:local line "test\n";
:put [ :pick $line 0 [ :find $line "\n" ] ];
Regards.
TealFrog
richedav
Tue Nov 15, 2011 4:52 pm
Thanks for the update - added to my cut.n.paste lists of code!
Users browsing this forum: No registered users and 33 guests
