KennethL
Find the Address-List to which an IP is assigned
Wed Oct 26, 2011 10:42 pm
Hi All,
I have searched the web, but was unable to find a solution to the following:
I have three address-lists configured, each driving workstations through three different WAN ports.
I just need a simple quick way (without using the GUI, so through the terminal) to find out to which list any particular IP belongs.. In other words, somthing like:
/ip firewall address-list get list where address=192.168.x.x
and as a return to the above, just spit out: list1, list2 or list3.
hope this makes sense, but let me know if you have any suggestions.
Thanks,
Kenneth
boen_robot
Re: Find the Address-List to which an IP is assigned
Wed Oct 26, 2011 11:44 pm
Although it's normally not a good idea to spoon feed such scripts, I've been wondering on what kind of sample scripts to work on that I might practice scripting with... so thank you for providing me with this opportunity, although I also kind'a feel gulty of taking it away from you :D .
Here's a script that does just what you said:
:local ip 192.168.x.x
:local result ""
:local delimiter ", "
:local fullList [/ip firewall address-list print as-value where address=$ip]
:foreach entry in $fullList do {
    :foreach part in $entry do {
        :local name [:pick $part 0 [:find $part "="]]
        :local value [:pick $part ([:find $part "="]+1) [:len $part]]
        :if ($name="list") do {
            :set result ($result . $value . $delimiter)
:put [:pick $result 0 ([:len $result]-[:len $delimiter])]
Just replace the first line with whichever IP you need. You could declare that variable as a global one, but in that case, you'd have to set it right before running the script.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
KennethL
Tue Jan 31, 2012 10:03 am
Hi Again,
I know it has been a while since you posted this, and realise that I never gave credit where it was due.
Therefore, just wanted to say thanks and confirm that your script worked BRILLIANTLY.
I really appreciated your input and it really did save me a lot of time and effort.
Thanks Again.
K
blake
Tue Jan 31, 2012 10:16 am
:put [/ip firewall address-list get value-name=list [find address=192.168.x.x]]
IT consultant. Network manager. Packet junkie.
1-928-328-1509
KennethL
Tue Jan 31, 2012 1:09 pm
Wow - this does the same thing..
Great stuff.. thanks Blake.
k.
betadineee
Mon Jan 28, 2019 6:17 pm
Hi, i got some error if there is the IP on multiple list,
> :put [/ip firewall address-list get value-name=list [find address=1.1.1.1]]
invalid internal item number
how i can see all of list that contains the ip?
please help me, thx before
Users browsing this forum: No registered users and 26 guests
