randallr
Script to check Port Speed "Rate"
Sun Jan 01, 2012 8:13 pm
When a switch can't maintain 100mbps it drops a port to 10mbps.
I'm trying to do a script that can email me if a Port is at 10mbps.
The "Speed" shows what's configured when "Auto-Negotiate" is disabled
The "Rate" shows what the Port is currently operating at.
"Rate" is shown on winbox screen, but not from cli in the Value-List, and I cannot figure out how to script it.
Thanks for any help!
janisk
Re: Script to check Port Speed "Rate"
Mon Jan 02, 2012 10:09 am
use this :
/interface ethernet monitor <interface>
here is sapmle output:
[admin@hs] > interface ethernet monitor ether1
            status: link-ok
  auto-negotiation: done
              rate: 1Gbps
       full-duplex: yes
          phy-regs: ...
randallr
Mon Jan 02, 2012 5:41 pm
Thanks for the reply.
My lack of scripting experience is now my problem-
I started with a simple script to check a single interface and create a log entry if true, but it doesn't work.
/int eth monitor ether2 once do={
:if ($"rate" = "10Mbps")
:log info "Ether2 is 10Mbps"
It doesn't execute from the Winbox screen, but from the Terminal, it brings up 'do: ' prompt, and execute correctly if I press enter.
Thanks!
randallr
Mon Jan 02, 2012 6:56 pm
Nevermind- I figured it out....
fsjis1
Fri Jan 27, 2017 11:34 pm
What did you figure out? Looking to do something similar. Thanks
rextended
Sun Jan 29, 2017 8:18 am
Just some examples:
/interface ethernet monitor ether2 once do={
 :if ($"status" != "link-ok") do={ :log info "ether2 is WITHOUT LINK"};
 :if ($"auto-negotiation" != "done") do={ :log info "ether2 auto-negotiation NOT WORKING"};
 :if ($"rate" != "100Mbps") do={ :log info "ether2 is NOT 100Mbps"};
 :if ($"full-duplex" = "no") do={ :log info "ether2 is NOT Full-Duplex"};
I'm Italian, not English. Sorry for my imperfect grammar.
rftnon
Sun Feb 12, 2017 8:26 pm
Thanks ...
This is useful and good ...
Users browsing this forum: No registered users and 21 guests
