MUM Europe 2020
DukeNukem3D
Change ip address of specific interface
Sun Mar 11, 2012 7:03 am
I have ether10 ip address 10.0.0.2/24.
Periodically I want to change it to 10.0.0.1/24
I read manual and saw that this is possible only using command:
/ip address set address=10.0.0.1/24 interface=ether10 numbers=
The problem is in numbers. I have to do
/ip address print
to get right item number. If item number will be changed, my script will change another interface ip address and I even can loose router's control.
I'm writng script and I need to change ip address o f specific interface, the question is:
is it possible to do something like
/ip address ?change? interface=... address=...
or is there some walkaround known, not to use item number.
airock
Re: Change ip address of specific interface
Sun Mar 11, 2012 9:52 am
You need a "number" in order to identify the address to change because, generally, an interface might have more than one address. So the interface name is not a "key" to an unique address.
If you are sure that your interface is assigned a single address you can use the following command:
/ip address set [/ip address find interface=ether10] address=10.0.0.1/24
anyway, with exactly the same semantics, a more proper solution would be:
/ip address set [/ip address find address="10.0.0.2/24"] address=10.0.0.1/24
From the latter you can clearly see what I said: you are working with addresses, not interfaces.
Regards,
rock
"Entia non sunt multiplicanda praeter necessitatem."
If you find anything useful in this this post, please give a positive Karma. (more info about Karma)
DukeNukem3D
Sun Mar 11, 2012 12:08 pm
Thanks, that's exactly what I need!
bastys
Sun Oct 21, 2018 2:31 pm
You can write the command as follows:
ip address set [/ip address find address="192.168.140.*"] address=192.168.141.*
I only want to change the C subnet of the ipaddress.
THX
kevigizmo
Mon Oct 29, 2018 12:08 pm
THX
I'm also looking for a similar command to the above where for example I have a number of sites which all have the site number set within the IP address,
so scripting wise for the "average person" to literally go in and edit 3 :global variables can change the single octet on the IP address
e.g - Change X to site number
:global SiteNumber=x
site 6 gets 10.1.6.254/24 for example,
and I need a command that does something like - add address=10.1.$SiteNumber.254/24 interface=loopback network=10.1.$SiteNumber.0
A friend had suggested something like
so address-begining = "10.10."; address-end = ".254/24"; full_address = $address-beginning . $6bit . $address-end;
But not sure whether this would work?
Any suggestions ?
Wireless & Network Consultant
¦ MTCNA MTCRE MTCINE MTCTCE ¦ UCT UBWS UBWA UEWA ¦
¦ SimRush Accredited Installer ¦ SimRush 4G | Redefining Superfast ¦
- DISCLAIMER -
All posts are advice, Otherwise Seek advice from manufacturer
Users browsing this forum: No registered users and 13 guests
