santajosh
check connected users how to
Wed Dec 21, 2005 10:04 am
Hi!
How can I check the connected users? Is there any SNMP MIB? I can check in the wireless setting, there are 6 users for example, but I like to put in a database this data. Is this possible?
And If I like to check the signal strengh? Is there an SNMP database?
Thanks!
Eugene
Forum Veteran
Forum Veteran
Fri Dec 23, 2005 10:38 am
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
YazzY
Fri Dec 23, 2005 10:45 am
The second option is to have your script ssh to your box, run a command, put it to a variable and work on it the way you want (grep, awk, sed etc).
Then you could insert the data to your database or store it as a flat text file.
Users browsing this forum: No registered users and 24 guests
