MUM Europe 2020
rviteri
Putting contents of a file into a variable
Sat May 05, 2012 10:46 am
Hello all I need to put the contents of a file which is over 4096 bytes into a variable. How can I do this?
c0d3rSh3ll
Long time Member
Long time Member
Re: Putting contents of a file into a variable
Sat May 05, 2012 10:30 pm
what is the contents?? ip adress??
nothing
rviteri
Sun May 06, 2012 3:40 am
Yes, I have a set of Ip addresses that I want to load into the router as address lists but its over 4096 bytes.
rviteri
Sun May 06, 2012 3:37 pm
I was able to accomplish the task using the perl API and sending my IP this way.
ditonet
Forum Veteran
Forum Veteran
Sun May 06, 2012 4:37 pm
My working solution:
Convert IP address list to script which adds IP addresses to 'Address List', then upload it via FTP.
If script file name ends with '.auto.rsc', eg. 'filename.auto.rsc' it will be executed automatically after upload,
if not simply execute 'import file-name=your_script.rsc' command.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
Users browsing this forum: No registered users and 20 guests
