ConnectiviaSrl
Dynamic DNS Update Script for No-IP DNS behind nat
Mon May 21, 2012 12:06 pm
Hi folks
we use the dyndns service from http://www.no-ip.com on our behind nat Mikrotik Router distributed around Connectivia sites.
For this reason we delivered (tested on RouterOs 5.x) a new one script as a merge of the two faboulous scripts already available on wiki.mikrotik.com to have a dyndns update script
specific for No-IP dyndns service when Mkt devices are behind nat. Thanks to the creator of changeip script published on Wiki page http://wiki.mikrotik.com/wiki/Scripts- We hope it's no problem to use the base or some parts .
Here you have the script :
#Dynamic DNS Update Script for No-IP DNS behind nat
# Set needed variables
:local username "uzername"
:local password "pazzword"
:local host "dreammachine.no-ip.org"
:global previousIP
# print some debug info
:log info ("Update No-IP DNS: username = $username")
:log info ("Update No-IP DNS: hostname = $host")
:log info ("Update No-IP DNS: previousIP = $previousIP")
# behind nat - get the publòic address using dyndns url http://checkip.dyndns.org
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "No-IP DNS: currentIP = $currentIP"
:if ($currentIP != $previousIP) do={
       :log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
       :set previousIP $currentIP
       :local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP&hostname=$host"
       :log info "No-IP DNS: Sending update for $host"
       /tool fetch url=$url user=$username password=$password mode=http dst-path=("no-ip_ddns_update.txt")
       :log info "No-IP DNS: Host $host updated on No-IP with IP $currentIP"
else={
   :log info "No-IP: update not needed "
# end
RouterOs Team @ Connectivia S.r.l
Networking - R&D Team @ Connectivia Srl
http://www.connectivia.it
normis
Re: Dynamic DNS Update Script for No-IP DNS behind nat
Wed Jun 06, 2012 2:30 pm
Thanks! Can you post this in our wiki?
nicholwee
Sun Jun 10, 2012 5:34 am
Great work! Thank you! :)
nicholwee
Sun Jun 10, 2012 5:43 am
Hi! I tested this script to work on RB450G with 5.17. However, just wanted to clarify whether we need to specify the gateway interface for this to be more effective. Because in my previous script, the gateway interface was specified. Thanks.
Ham
Tue Jun 12, 2012 6:31 am
Thanks you for writing this script nicholwee, it's been working a treat.
screenname
Tue Jun 19, 2012 6:27 pm
Thank you for the script and a suggestion for enhancement. Because my IP address don't change often, I still get the monthly e-mail remind me to log into my no-ip.com account. Can the script be changed so it will update with a dummy IP first then the real one every X days?
Thank you again.
saintofinternet
Forum Veteran
Forum Veteran
Sat Aug 24, 2013 6:05 am
not working in ver 6.0
the files are not getting created.... nor is the no-ip page getting updated...
by professionals, for professionals....
Don't forget to give KARMA!!!
fuba
Fri Jul 04, 2014 5:14 am
I got this to work on ver. 6.15.
Found it here
:local username "your no-ip user login"
:local password "your no-ip password"
:local host "your no-ip host name"
:global previousIP
# behind nat - get the public address using dyndns url http://checkip.dyndns.org
:delay 2
:log info "dyndns result = $result"
:local currentIP [pick $result $startLoc $endLoc]
:local url "http://dynupdate.no-ip.com/nic/update/?myip=$currentIP&hostname=$host"
:delay 2
:local result [/file get "no-ip_ddns_update.txt" contents]
:log info "Update Result = $result"
} else={
# end
kasser010
Re: Dynamic DNS Update Script for No-IP DNS behind NAT
Fri Jun 19, 2015 10:55 am
I've created a newer Updater which includes the following features:
[*]using IP Cloud to get the public IP (requires ROS v6.14)
[*]updating the host via https
[*]automatically updates every 3 minutes
[*]does not create any files
Just copy the following Code into a textfile
edit the USER,PASS and HOST
and paste it into the CLI and it will create the Updater:
ROS Version >= 6.27
1. Add a script with read,write,test policy called no-ip_update:
#Dynamic DNS Update Script for No-IP DNS behind NAT
:local username "USER"
:local password "PASS"
:local host "HOST"
:global previousIP
# behind NAT - using MikroTik IP Cloud feature
#current IP
/ip cloud force-update
:delay 5
:local currentIP [/ip cloud get public-address]
#compare IPs
:if ($currentIP not $previousIP) do={
#current IP overrides previous
:local url "https://dynupdate.no-ip.com/nic/update/?myip=$currentIP&hostname=$host"
#sending infos which are required in the no-ip API via https
/tool fetch url=$url user=$username password=$password mode=https keep-result=no
} else={
# end
2. Put the following code into the CLI:
/ip cloud set ddns-enabled=yes
/system scheduler add name=no-ip-updater disabled=no interval=3m policy=read,write,test  on-event=no-ip_update
ROS Version 6.14 to 6.26
:local host "HOST"
:global previousIP
#current IP
:delay 5
#compare IPs
} else={
# end
/ip cloud set enabled=yes
djynny
Wed Dec 09, 2015 6:31 pm
ROS Version >= 6.27
Code: Select all
:local host "HOST"
:global previousIP
#current IP
:delay 5
#compare IPs
:local url "https://dynupdate.no-ip.com/nic/update/ ... name=$host"
} else={
# end
I have tried this no ip updater behind nat and I am using RouterOS 6.29
But it seems it is not working. It just displays that my dynamic public IP changed but can't update it to noip.
https://drive.google.com/file/d/0B19T49 ... sp=sharing
Djemmy
djynny
Wed Dec 09, 2015 6:48 pm
I think I solved it.
#compare IPs
should be
I think it just typo mistake.
Thanks for the script.
gbroin
Wed Sep 19, 2018 6:43 pm
It did not work for me, but I think I solved it:
Code: Select all
:local host "HOST"
# Get Previous IP
:local previousIP [/put [:resolve $host]]
# Get Current IP using MikroTik IP Cloud feature
:delay 5
# Logging IPs
:log info "No-IP: Previous IP = $previousIP"
:log info "No-IP: Current IP = $currentIP"
#compare IPs and update host if needed
:log info "No-IP: Current IP ($currentIP) is not equal to previous IP ($previousIP), update needed"
:log info "No-IP: Sending update for $host"
:log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
# end
Users browsing this forum: No registered users and 6 guests
