daan99
Firewall visualize.
Sun Aug 26, 2012 9:04 pm
I am writing a script to visualize firewall rules, do you think it's useful for someone? If so I'll have the motivation to do it as a CGI.
Picture on http://blog.asgard-gate.net/index.php/2 ... -mikrotik/
boen_robot
Re: Firewall visualize.
Sun Aug 26, 2012 9:59 pm
Add the ability to group by arbitrary attribute (not just chain) on not just filters, but also NATs and mangles, and this tool will be invaluable for debugging and training alike.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
daan99
Sun Aug 26, 2012 10:27 pm
The objective is to group the NAT, mangle and filter. In addition, I think about the interfaces or IP addresses filters.
boen_robot
Sun Aug 26, 2012 10:49 pm
Filtering would be nice, but IMHO, a grouping in a similar way to the screenshot, but with another parameter, would make it all that more readable.
I mean, it would be really nice being able to see the full rules that a packet with a certain pattern (IP address, interface, etc.) will end up matching across the firewall. I can imagine such investigation revealing false positives or extra rules that never get matched.
daan99
Tue Aug 28, 2012 11:33 am
This week I will try to put the script to test for the world :). I also think to generate more dynamic AJAX, JS flowcharts, not just static pictures. But first good parser, then bells and whistles :)
boen_robot
Tue Aug 28, 2012 12:10 pm
You don't need a good parser. That's what the API is for - an interface where the data is trivial to parse (and in fact, many clients do already have parsers). Simply work trhough it instead of SSH.
A dynamically arranged chart (like literally being rearranged on-the-flyi as you move and click on stuff) would be truly awesome, but I think having just an SVG graphic with a clickable link, which in turn generates a new SVG graphic would still be cool (and of course, useful), while probably being easier to implement. I mean, how did you draw that thing there? GraphViz I'd assume? I believe GraphViz does have the option to generate links over graph nodes when SVG is being generated.
fluxburn
Wed Aug 29, 2012 5:40 am
Hum, I find visual diagrams essential for understanding systems. I'll try this out.
shadowskippie
Wed Aug 29, 2012 6:48 pm
this i like....can't wait to see it in action
daan99
Fri Aug 31, 2012 2:56 am
Parser is for rsc files, SSH is good for read data, there is no need to open next port on router.
The form on the right, very early version (Feel free to kill it :) ).
http://neutrino.asgard-gate.net/index.p ... 2012-09-31
boen_robot
Fri Aug 31, 2012 4:49 pm
Oh. I see. Your current implementation visualizes an ".rsc" file.
Well, if you use the API or SSH, you can visualize a live router instead. If you do that, I'm sure you'll find the API significantly easier to work with than SSH. I mean, the API was after all designed to be easy to work with programatically.
Do you have the source of that app available somewhere? Maybe I could make a different version that uses the API. Or (if you've already abstracted things in a good enough fashion) add the API as an additional option.
daan99
Sun Sep 02, 2012 11:04 pm
Application source code will be made available by the GIT repository as soon as I deal with it.
The application is meant to be divided into 3 layers, a collection of data (API files. Rsc, SSH), processing (filters) and display (Graphviz for now....).
daan99
Wed Sep 05, 2012 9:49 pm
A little fun with JS and HTML elements can be moved :)
http://neutrino.asgard-gate.net/index.p ... javascript
AnRkey
Thu Sep 27, 2012 1:38 pm
Oh please please please open source this. It's a very cool idea!
MTCNA
daan99
Thu Oct 04, 2012 12:29 am
View of the target application and info available at this link .
and a small demo here.
Take a look, and comment :)
Users browsing this forum: romakov and 22 guests
