mixig
Log pppoe change status
Thu Sep 27, 2012 9:29 pm
can someone write down how to monitor status of pppoe interface and log that to a txt file which will be saved on mkt on disk (under the "Files"):
date, time, pppoe-out1 down
date, time, pppoe-out1 up
AnRkey
Re: Log pppoe change status
Fri Sep 28, 2012 11:32 am
You can disable the default logging rules under System > Logging
Then create your own log rules, explained here > http://wiki.mikrotik.com/wiki/Manual:Sy ... figuration
I'd look into the debug info, that increases the verbosity of the logging quite a bit. You would have to add exclusions for the info you don't want though, which might be tricky.
Post your results here, maybe it helps someone in turn.
MTCNA
Users browsing this forum: No registered users and 13 guests
