botter911
Simple PHP check
Sun Oct 07, 2012 12:25 pm
Hi guys, I cannot get this script to work. Can you please tell me where i went wrong?
<?php require_once("routeros_api.class.php");
/**** Function to send SMS via Mikrotik SMS Gateway ***/
function send_sms($number, $text) {
global $smsgw;
$API = new routeros_api();
if ($API->connect("192.168.88.1", "admin", "admin")) {
$API->comm("tool sms send usb2 channel=3 phone-number=1234 message=test");
} else {
echo "error";
return "could not connect to mikrotik gateway";
send_sms("1234", "test");
boen_robot
Re: Simple PHP check
Mon Oct 08, 2012 7:30 pm
The API protocol uses a very different syntax from the shell.
Using the client from my signature, you can use a shell-like syntax... the main difference being that you must explicitly specify ALL argument names. In your case, that would be:
<?php
namespace PEAR2\Net\RouterOS;
require_once 'PEAR2_Net_RouterOS-1.0.0b3.phar';
    global $smsgw;
    try {
        $API = new Client("192.168.88.1", "admin", "admin");
        $API->sendSync(new Request("/tool sms send port=usb2 channel=3 phone-number=1234 message=test"));
    } catch (Exception $e) {
        echo "error";
And if you want to use your current client, you'll have to follow the API syntax, per the spec.
(Side note: On my RouterOS, the phone number is specified with the "dst" argument, not the "phone-number" argument... what RouterOS version are you using?)
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
wencs
Mon Oct 31, 2016 12:23 pm
yo lo e resuelto de la siguiente manera:
<?php
require(PATH_BASE.'/dist/api/mikrotik/routeros_api.class.php');
global $smsgw;
$server = '192.168.1.1';
$loginname = 'user_admin';
$password = 'password';
$artv_puerto = 8728;
$modeom = array();
$API->debug = false;
$API->port = $artv_puerto;
if ($API->connect($server, $loginname, $password)) {
$comandomk='/tool/sms/send';
$modeom['port']='usb3';
$modeom['channel']=2;
$modeom['phone-number']=$number;
$modeom['message']=$text." a las ".$time1;
$resultado=$API->comm($comandomk,$modeom);
if (is_array($resultado)) {
if (isset($resultado['!trap'][0]['message']) ) {
$message = $resultado['!trap'][0]['message'];
print "Error: ".$message;
}else{
print "<br/>mensaje enviado con exito";
$API->disconnect();
$numero= "+584142351570";
$Empresa ="Finandanzas Telecom, CA. ";
send_sms($numero, "Estimado cliente hemos recibido su pago por un monto de 3900,00 el recibo sera enviado a su correo ".$Empresa);
Users browsing this forum: MSN [Bot] and 22 guests
