David1234
script that send mail whwm Ip cahnge
Wed Nov 14, 2012 2:14 pm
Hello
I want to write a script that will run every 1 hours and check the IP I get and send me an E-mail if it's change.
this is what I wrote so fat
my problem is how to save the old ip \where to put him
:global newip [/ip address get [find interface=ppp-out1] address];
:log warning "New IP is-$newip";
:if ($oldip !=$newip) do={:log warning "IP change to-$newip";
/system script run mail;
:global oldip=$newip; } else={:log warning "IP didn't change";:global oldip=$newip; };
:log warning "******script finish******";
thanks ,
NAB
Trainer
Trainer
Re: script that send mail whwm Ip cahnge
Wed Nov 14, 2012 6:45 pm
Easiest place is in a comment field. In my experience, the best place is on the interface the DHCP server is running on (/interface etherX set comment="1.2.3.4") - that way it survives reboots and power cuts.
c0d3rSh3ll
Long time Member
Long time Member
Wed Nov 14, 2012 7:57 pm
try this
:global oldip;
:local newip [/ip address get [find interface=ppp-out1] address];
/system script run mail; set oldip $newip} else={:log warning "IP didn't change"; };
nothing
David1234
Thu Nov 15, 2012 10:42 am
this is good option
I did something else - I wrote the value into a file and then read\write to him.
but I'll try it also
Thanks !
1 more thing -
maybe you know how I can cancel the subnet of the ip
I get 91.152.24.87/32
I want to get only the 91.152.24.87
that way I can send the ip as a link
thanks ,
c0d3rSh3ll
Long time Member
Long time Member
Fri Nov 16, 2012 3:32 am
like this
:local ip [/ip address get [/ip address find interface="wan"] address]
:local currentIP [:pick $ip 0 [:find $ip "/"]]
put $currentIP
nothing
David1234
Sun Nov 18, 2012 10:48 am
Thank you!
1 more question -
how can I see the IP as a link? so the person will press it and go directly to the IP
in the E-mail I see this as a text - and not as a link
c0d3rSh3ll
Long time Member
Long time Member
Mon Nov 19, 2012 3:18 am
put "http://$currentIP"
nothing
David1234
Mon Nov 19, 2012 9:14 am
Thanks !
(again)
Users browsing this forum: icarosimoes and 22 guests
