Ehman
import rsc file, want to continue with errors? need help
Mon Jan 28, 2013 1:04 pm
Hi
I want to import a script, that will continue with errors? because if I drop the same code into the terminal it does exactly what I want it to do, but but but... if I drop that same code into a rsc file and import it .....it pops a error when I import it... :shock:
cbrown
Trainer
Trainer
Mon Jan 28, 2013 1:10 pm
Run it in terminal again and read the output to see where your problem is and fix it.
Although it would be nice, there is no force option make it continue with errors.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Next Training
https://www.cbrown.co/2019/04/08/mtcna-june2019-wv/
Ehman
Re: import rsc file, want to continue with errors? need help
Mon Jan 28, 2013 1:17 pm
the problem is, when I import a certificate:
I have to drop this code into the terminal:
/certificate import file-name=ca.crt
123456789
/log info "certificate imported"
and then it imports my certificate without any issues, but I want to load that stuff into a .rsc file to do it all
no error if I copy and past the code, but when I run it, its doesnt wanna except the passphrase, its doesnt allow to add a phaseprase="" command in the first place :shock:
Users browsing this forum: No registered users and 7 guests
