MUM Europe 2020
ciscosystem
slow-browsing
Mon Feb 11, 2013 3:03 pm
hi everybody
we have a network based on mikrotik routerboards but we have a problem with some of our customers they have good download speed but very slow browsing . what could cause this ? i use same dns add that works good for everybody else , could bad wireless config cause that ?
boen_robot
Re: slow-browsing
Tue Feb 12, 2013 2:03 pm
A bad visibility, low power transmitter and/or receiver, too many other wireless devices being near and on the same or near channels...
Yep... a bad wireless configuration is probably it.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
ohara
Re: slow-browsing
Tue Feb 12, 2013 8:51 pm
There can be many different reasons, just as boen_robot said. If your customers use Windows, try disabling 'Automatically detect settings' option in Control Panel>Internet Options>Connections>Lan settings.
ciscosystem
Re: slow-browsing
Wed Feb 13, 2013 7:13 am
thank u ohara and boen_robot but the problem still stands :(
ohara
Re: slow-browsing
Wed Feb 13, 2013 8:39 am
slow browsing can be caused by high latency. Therefore it might be worth to check ping times from a customer's device to the gateway and separately from a customer's wiresless router to the gateway. If you post a diagram of your network it would be easier to give you some advice.
salytwo
Re: slow-browsing
Thu Apr 17, 2014 8:41 am
I have the same problem, downloading is fast while browsing is slow.
I did remove all queues and make it very basic setup. like hotspot with IP binding (80 clients) one rule as NAT.
but the speed of browsing is slow.
can anyone help please
jarda
Re: slow-browsing
Thu Apr 17, 2014 9:15 am
Maybe slow or overloaded dns. Try to use pubic dns right on users computer. If it makes difference check your dns servers.
Users browsing this forum: No registered users and 20 guests
