neandero
Script communication between multiple routers?
Sat Feb 16, 2013 4:31 pm
is there a way to call a script on one router to execute a script on another router?
thanks in advance,
ohara
Re: Script communication between multiple routers?
Sat Feb 16, 2013 5:38 pm
This command executes the script 'yourscript' on router 192.168.1.2. The script is saved on the same router that it is executed on.
ros code
system ssh 192.168.1.2 user=admin "/system script run yourscript"
neandero
Sat Feb 16, 2013 6:45 pm
excellent, my road here is "ssh".
Thank you & Please accept my Karma :D
neandero
Sun Mar 31, 2013 6:19 pm
without having a linux box, how to create a passkey so it won't ask for password?
this is script communications between mikrotik to mikrotik only.
thanks in advance..
ohara
Sun Mar 31, 2013 8:32 pm
This can be achieved with importing ssh public key on your mikrotik device.
http://wiki.mikrotik.com/wiki/Use_SSH_t ... key_login)
neandero
Mon Apr 01, 2013 1:14 am
the wiki provided involve linux box. is there any way to use just mikrotik routers?
i was able to create a user on remote mikrotik device without password and log-in using terminal
/system
ssh 192.168.1.1 user=myuser
but when using the same user in a script won't work
/system ssh 192.168.1.1 user=myuser ":log info hello"
neandero
Mon Apr 01, 2013 2:41 am
I followed the guide and still not a good result:
on ubuntu:
ssh-keygen -t dsa
Enter file in which to save the key:
"key"
no password
both file key & key.pub was copied to both routers (routerA and routerB)
on routerA
create user sshadmin (no password)
import ssh key
user = sshadmin
key file = key.pub
on routerB
import ssh private key
user = sshadmin
public key file = key.pub
private key file = key
passphrase = (blank)
on routerB create new script
/system ssh 192.168.1.1 user=sshadmin ":log info hello"
what's my mistake here?
thanks,
payday
Tue Apr 02, 2013 8:31 pm
You can also try an xxxx.auto.rsc file:
"Since RouterOS v3rc it is possible to automatically execute scripts - your script file has to be called anything.auto.rsc - once this file is uploaded with FTP to the router, it will automatically be executed, just like with the Import command."
Source: http://wiki.mikrotik.com/wiki/Manual:Co ... Management
To upload file you can use /tool fetch command, example:
[admin@mt-test] /tool> fetch address=192.168.88.2 src-path=conf.rsc user=admin mode=ftp password=123 dst-path=123.auto.rsc upload=yes
Source: http://wiki.mikrotik.com/wiki/Manual:Tools/Fetch
But, be aware of some bugs: http://forum.mikrotik.com/viewtopic.php?f=9&t=62261
Users browsing this forum: No registered users and 9 guests
