macrob86
Ddns on RB750 OS 5.11
Mon Mar 25, 2013 11:55 am
I´ve tried more than 10 scripts to DDNS but I did not get to do work. I tried scritp for Dyndns and change ip.
If anyone has a script that work well on RB 750, OS 5.11, please send me.
nmaton
Re: Ddns on RB750 OS 5.11
Mon Mar 25, 2013 11:19 pm
This script works :
Just don't forget to put a scheduler to run it after xx minutes, hours.
------- START COPYING AFTER THIS LINE -------
#DYNDNS SCRIPT ROUTEROS !!!
#INSERT THIS IN THE SYSTEM SCRIPTS
# Set needed variables
:local username "username"
:local password "password"
:local hostname "yourdyndnsname.dyndns.org"
:global dyndnsForce
:global previousIP
# print some debug info
:log info ("UpdateDynDNS: username = $username")
:log info ("UpdateDynDNS: hostname = $hostname")
:log info ("UpdateDynDNS: previousIP = $previousIP")
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "UpdateDynDNS: currentIP = $currentIP"
# Remove the # on next line to force an update every single time - useful for debugging, but you could end up getting blacklisted by DynDNS!
:set dyndnsForce true
# Determine if dyndns update is needed
# more dyndns updater request details available at http://www.dyndns.com/developers/specs/syntax.html
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
:set dyndnsForce false
:set previousIP $currentIP
/tool fetch user=$username password=$password mode=http address="members.dyndns.org" src-path="/nic/update?hostname=$hostname&myip=$currentIP" dst-path="/dyndns.txt"
:local result [/file get dyndns.txt contents]
:log info ("UpdateDynDNS: Dyndns update needed")
:log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
:put ("Dyndns Update Result: ".$result)
} else={
:log info ("UpdateDynDNS: No dyndns update needed")
------- STOP COPYING BEFORE THIS LINE -------
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
macrob86
Tue Mar 26, 2013 9:21 pm
Very good. Thank you very much.
Works well.
If you have the changeip scrip too. Please send me.
Regards.
Users browsing this forum: No registered users and 14 guests
