siberia
Can i send a command as a parameter in microtik API
Wed Apr 03, 2013 9:21 pm
Hi. i am testing the API interface i have developed through java API.
what i need is to send a command to change the ip address of a user.
actually i have to acomplish this work , sending to separate commands:
1) I send this command first to get the user id :
/ppp/secret/print
?name=smith
=.proplist=.id
it returnrs :
!re
=.id=*7
!done
2) next i have to send a command to change the ip to the returned id:
/ppp/secret/set
=.id=*7
=remote-address=10.12.10.50
so i want to know if there is a way to get this result in a single script ??
i tryed to change the ip using the name instead of the id but it din't work/
thanks regards !
boen_robot
Re: Can i send a command as a parameter in microtik API
Thu Apr 04, 2013 12:12 am
Try
/ppp/secret/set
=numbers=smith
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
siberia
Thu Apr 04, 2013 12:42 am
Smith.
thanks you very much. it worked ! :)
do you got some reference where i can learn or find information about ppp commands that i can use with API.
thanks again.
boen_robot
Thu Apr 04, 2013 1:07 am
API commands closely follow shell commands.
When you're at a terminal, type the command and then press "?" to see the arguments it can accept.
In terminal, you can omit the names of some arguments, but in API, you are required to specify all of them. If the name of an argument can be omitted in terminal, it will be surrounded with "<" and ">".
A typical argument for targeting entries is "numbers". The API version of this argument can accept anything its shell equivalent can except numbers (ironically enough), although it can accept an ID. So - if in terminal you can target an entry with something other than a number, you should be able to do the same from the API.
siberia
Thu Apr 04, 2013 1:28 am
Good enough explanation.
thanks again man ! :)
rumiclord
Tue Apr 09, 2013 11:14 pm
Is there a way to input a user command during a script ?
example: -- [Q quit|D dump|C-z pause]
how do I tell the script to simulate the user pressing the q button to quit the current command?
janisk
Wed Apr 10, 2013 12:32 pm
in CLI you cannot do anything else but run continuous command. However you can open new cli to continue work.
In API you can run multiple commands and use .tag to tag those, so you can run several and manage how long each of the runs. and what reply comes from what continuos command.
siberia
Wed Apr 10, 2013 6:07 pm
H Janisk, excellent information.
can you give us some sample ?
tanks
boen_robot
Wed Apr 10, 2013 6:47 pm
In terms of protocol flow, it might look something like:
/ping
=address=127.0.0.1
=.proplist=time
.tag=localhost
/ping
=address=192.168.0.100
=.proplist=time
.tag=admin
!re
.tag=localhost
=time=1ms
!re
.tag=admin
=time=1ms
!re
.tag=admin
=time=1ms
!re
.tag=localhost
=time=1ms
You'd have to inspect every reply from the getData() method, and see what it says after ".tag=".
siberia
Wed Apr 10, 2013 8:15 pm
thanks
SandroDIniz
Wed Apr 17, 2013 6:44 pm
you have files dynamically in a page with PHP creation, modification and deletion of rules, settings MK web php
rogeriomaciel
Wed Oct 31, 2018 9:45 pm
Could you please help me with a little code? I need to execute the command to change the name of MikroTik but I am not able to pass the parameters in the API in Swift. It's different from the PHP API. I've tried in many ways..
api.sendCommand(command: "/system/identity/set/name=TEST")
api.sendCommand(command: "/system/identity/set/=name=TEST")
api.sendCommand(command: "/system/identity/set\n=name=TEST")
As none of these worked, what would be the correct way to execute the commands passing parameters?
Thanks for the help.
Users browsing this forum: No registered users and 6 guests
