MUM Europe 2020
toto
Looking Glass
Tue Jun 18, 2013 6:31 pm
Hi everyone,
until now, there wasn't any serious looking glass available for Mikrotik. This. Changes. NOW! :D
Alpha version, but it works fine for pings & traceroutes.
This is what you get http://i.imgur.com/cuEH7si.png
https://github.com/TomHetmer/MikroGlass
Tom.
raz
Re: Looking Glass
Fri Jun 21, 2013 12:28 am
Thanks Tom, its useful. :-)
mandrade
Re: Looking Glass
Sat Jul 13, 2013 2:57 pm
Hi everyone,
Tom.
*NOT* found in github link, any other link?????
BR
HaPe
Re: Looking Glass
Sun Jul 14, 2013 12:44 am
Hi everyone,
Tom.
Here http://ug.runtimeapp.com/
BR
In anticipation on new The Dude release.
sohel2020
Re: Looking Glass
Thu May 01, 2014 2:10 pm
How do i install it.
There is no tutorial.
Where i put my mikrotik router server name and password?
Can any one plz write a short tutorial.
plz plz plz i need it badly.
maximan
Trainer
Trainer
Re: Looking Glass
Wed May 07, 2014 5:32 pm
Nice work!!
I will use it. Nice source code, clean & simple (KISS). I like it!
I give your karma
M.
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
boen_robot
Re: Looking Glass
Thu May 08, 2014 4:28 pm
In regards to your setup notes:
1.API service will not help you, this is done using SSH. API in Mikrotik does not support traceroute, pings, etc.
That is false. The API supports "/ping", as well as "/tool ping" and "/tool traceroute". Yes, the output is different, and needs to be processed, and your app may not support the API... But the API protocol itself does support these.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
raminmalek
Re: Looking Glass
Thu Nov 23, 2017 10:10 pm
I setup by https://github.com/TomHetmer/MikroGlass ... P-version)
Install putty and update config file by not work
Whitch version Of Php Used for this code??
I see php.ini
Disable function is empty LINE
raminmalek
Re: Looking Glass
Thu Nov 23, 2017 10:18 pm
I use version php-5.3.3-49.el6.x86_64
For code install apache and php only
Install putty
the webserver havenot any log in router
Users browsing this forum: No registered users and 19 guests
