Code: Select all
:if ($resolvedIP != $currentIP) do={
highlighted where this always worked in v.5.x
Why is this and how to correct it?
(I hate it when we see major changes in ROS the scripting also changed. How can you ever implement scripting on a wide scale base if they have to be re-written each time you run an ROS update.... very bad....
