RoddyZ
To retain variable's values after reboot
Wed Mar 22, 2006 4:15 pm
Any know how to retain variables's values after reboot the MT, saving this values to disk ?
-Roddy
cmit
Wed Mar 22, 2006 4:54 pm
Just an (untested) idea:
In your script create another script that is setting the (global) variable you want to retain to its' current value. Then create a scheduler entry to execute this script only once at startup (which should be working now?!).
Every time your variable does change remove the "I recreate the variable"-script and re-create it so that it sets the variable to the new value.
By the way: It would be nice to have a console command to write something arbitrary to a file (like the :log command, just with an additional "file" parameter and the ability to choose between append and overwrite mode).
Best regards,
Christian Meis
RoddyZ
Thu Mar 23, 2006 1:14 am
I found a new solution using firewall chains
Replace variable_name with the true name of your variable, and variable_value with his value
To create a new variable:
/ip firewall filter add chain=variables comment=variable_name content=variable_value
To read the variable value:
:put [/ip firewall filter get [find chain=variables comment=variable_name] content]
To update the variable value:
/ip firewall filter set [find chain=variables comment=variable_name] content new_value
To remove the variable:
/ip firewall filter remove [find chain=variables comment=variable_name]
The chain "variables" is never ejecuted, avoid cpu load
-RoddyZ
cmit
Thu Mar 23, 2006 11:35 am
Nice one, too ;)
Best regards,
Christian Meis
RoddyZ
Fri Mar 24, 2006 12:46 am
cmit:
Thinking in your script idea, i create the follow script to recreate all global variables in the startup, with a autoexec scheduler (like: http://forum.mikrotik.com//viewtopic.ph ... t=autoexec).
:foreach i in=[/ip firewall filter find chain=variables] do={
:log info ( "Loading variables: " . [/ip firewall filter get $i comment] . "=" . [/ip firewall filter get $i content] )
:global [/ip firewall filter get $i comment] [/ip firewall filter get $i content]
But, is better to have a more efective way to retain variables, MT team, please take note ...
-RoddyZ
BuayaDarat
Re: To retain variable's values after reboot
Thu May 29, 2014 9:34 am
i'd use [/ip firewall layer7-protocol] instead of [/ip firewall filter], since it's safer and will not accidentally disturb the filter rules, also the regexp can store more data.
palii
Sat Apr 20, 2019 8:06 pm
13 years later. Well, I wrote a function that reads and writes persistent variables as layer7-protocols.
:global persist do={
    :local varName $1
    :local varValue $2
    :local varID [/ip firewall layer7-protocol find name="$varName"]
    :if ([:typeof $varValue] = "nothing") do={
        :if ($varID != "") do={
            :set $varValue [/ip firewall layer7-protocol get $varID value-name=regexp]
    } else={
        :if ($varID = "") do={
            /ip firewall layer7-protocol add name="$varName" regexp="$varValue"
        } else={
            /ip firewall layer7-protocol set $varID regexp="$varValue"
    return $varValue
Usage examples: (name = variable name, value = variable value)
  • $persist name = Read persistent variable
  • $persist name value = Write persistent variable
  • :global name [$persist name] = Read persistent variable and write it to a global variable
  • :global name [$persist name value] = Write data into a global variable and into a persistent variable at the same time
Notes:
  • The function uses layer7-protocols to store persistent data.
  • All data read from persistent storage will be strings.
  • The function always returns a value.
Jotne
Sat Apr 20, 2019 10:27 pm
Did not see that before.
Why in the earth does not the RuterOS retains the global variable after reboot.
This should be a simple ting for MT to implement???
So MT consider this as a request.
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
tishri
Tue Dec 01, 2020 2:31 pm
sometimes you need some variables that stay even after a reboot
For example:
A script that reboots if the internet connection is down or a certain type of attack is detected.
You need to keep track of your number of reboots until a script has to stop rebooting itself.
mrz
Tue Dec 01, 2020 4:40 pm
Write variables in scheduler startup script is a better option than writing variables in l7 rules and other crazy stuff.
Jotne
Tue Dec 01, 2020 6:47 pm
How com storing a variable inn to the script section is less crazy than storing it in a l7 rule?
Could you post an example?
Why not just retain variable after reboot when its stored as a global variable?
MikroTik->Splunk
Larsa
Tue Dec 01, 2020 7:36 pm
:persistent variable
or...
:global::persistent variable
WeWiNet
Tue Dec 01, 2020 8:28 pm
I am sorry to say but half of the forum is using L7 as variables.
If there is a better way then please post example.
AND, having LTE traffic counter as such variable should be built into ROS...
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? or maybe I am just crazy :lol: !!!
SiB
Tue Dec 01, 2020 10:55 pm
mrz
  • But... what with rapid power-off... data will be lost !
    L7 stay with latest one value ever reboot.
  • But... scheduler will be create GLOBAL variable to other scripts can use it.
    Better is we stay with local and not use to many global.
    Each script can create local or global when he start, we not want a variable without latest value from before reboot.
  • But... from scripting level we cannot edit the variable=value in some one line of scheduler on-event code!
    We cannot do export from only one scheduler to file,
    We cannot edit it via sed&awk - not work here... we not have proper workaround...
Layer7 is best option.
Scheduler StartUp for creating global variables who will be reading latest variable from NAND ? This is even worst then L7.
Of course we can do more crazy idea :) like creating new bridge-variable1, Value in commend but still, L7 is better.
Future Suggestion: Image
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
msatter
Wed Dec 02, 2020 12:08 pm
Can we have a scheduler restart/shutdown then?
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet.
Running:
RouterOS 6.48 / Winbox 3.27 64bits
mrz
Wed Dec 02, 2020 1:14 pm
Can you show any other scripting language or programming language where defined variables magically restores their values from previous script instance, without saving data to file, registry or database? If you want to save something handle it in your code.
With L7 is the same as with scheduler configuration you have to write changes. If you do not write latest changes to scheduler or even your used L7 then of course nothing is saved.
Benefit of using startup scheduler is that you do not need to read and parse variables, they are just loaded at startup automatically.
Local variables are local to the scope, saving them does not make any sense. There is nowhere to restore them because local scope does not exist anymore when script is finished.
msatter
Wed Dec 02, 2020 2:28 pm
This can be adapted to write global variables to a file: viewtopic.php?f=9&t=167594&p=823889&hil ... le#p823683
I advise to only do variables and not scripts due to the 4096 bytes limitation. If you mark functions with the wordpart func in the name and those variables that not should be saves with nosafe
Example:
:foreach in environment do
:if variablename ~ "(func|nosafe)" do{} else{safe to file by using append}
Then use scheduler on startup to read back the variables into environment by using :global
Running:
SiB
Wed Dec 02, 2020 2:56 pm
I understand you, what ever it's stored, persistent env are know stuff and we can use them like `setx /M path "%path%;C:\your\path\here\"`
Scheduler way must do
  • scheduler-env-startup - he create a global with default value
  • scheduler-run-own-finall-app - this will be change our global
  • scheduler-env-udpate - every x time it grab all global and replace data in scheduler-env-startup
better way is store that variable at /flash/env.txt and load/update them from schedulers because editing body of other script/scheduler is not easy at ros without sed&awk.
Still Layer7 works so perfect and we use that thank by just 1 line of code, we can stay with local, what means this is almost perfect.
In reality... many times a workaround life longer then solution :)
Jotne
Wed Dec 02, 2020 3:05 pm
That is not important. From my time with MT Router this has been something that many of us like to have. Yes there are several workaround File/Script/L7 etc, but why not implement it? Should be easy to do. Look at Larsas post above..
See this post as an formal request for presistant variables.
MikroTik->Splunk
Larsa
Wed Dec 02, 2020 3:27 pm
Automatic persistent variables is a piece of cake using for example Javascript, TCL, Python, Powershell, Apple Automator, etc. But since the RoS script engine is a crippled TCL look-alike which lacks a working storage engine we probably won't be blessed with that kind a functionality in the near future. :-(
SiB
Wed Dec 02, 2020 4:18 pm
+1
Users browsing this forum: No registered users and 25 guests
