maximt
is there any associative array, hash, map?
Sat Aug 17, 2013 10:53 am
boen_robot
Re: is there any associative array, hash, map?
Sat Aug 17, 2013 4:26 pm
The change log for 6.2 implies that there is in that version with the statement:
*) console - array value syntax in expressions '{1;2;3;4}' now can
specify values with word keys as '{a=1;b=2}';
but I don't really see it working as you'd expect, i.e.
ros code
:pick $assoc "a"
will NOT give you the element with a key called "a", and there isn't a different command that would. What's more puzzling is that
ros code
:pick $assoc 0
will not give you just the value, but also the "a=" prefix... in other words, it's EXACTLY as if associative arrays are not supported at all, and you're getting a plain ol' string.
I guess what the change is ACTUALLY saying is that is no longer considered a syntax error (but is instead interpreted as a plain string), whereas it previously would be.
With all that said - apparently no. There are no associative arrays in scripting (yet?).
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
maximt
Sun Aug 18, 2013 9:02 am
I wrote two helper functions to store values in environment as global vars.
but there is bug - you can pass variables to functions.
Waiting for 6.3...
ros code
:global setHashValue do={
	:global hashSetter [:parse ":global $1$2 $3"];
	$hashSetter;
:global getHashValue do={
	:global hashLastValue nil;
	:global hashGetter [:parse ":global $1$2 ; :global hashLastValue \$$1$2" ];
	$hashGetter;
	:return $hashLastValue;
$setHashValue "myHash" "keyA" 123;
$setHashValue "myHash" "keyB" 456;
$setHashValue "myHash" "keyC" 678;
:log info [$getHashValue "myHash" "keyA"];
:log info [$getHashValue "myHash" "keyB"];
:log info [$getHashValue "myHash" "keyC"];
boen_robot
Tue Sep 17, 2013 3:00 pm
I just saw this topic, which seems to suggest that there ARE associative arrays, and you can access a key with
$array->"key"
But then, I tried to define one from scripting, but never managed to match a key (an empty string was returned instead). I tried
:local assoc ({},"a"="test1")
:local assoc ({"a"="test1"})
:local assoc {"a"="test1"}
all with the same result.
Side note - that last syntax produces an array with two numeric members - value "a" at offset 0, and "test1" at offset 1.
(I'm using 6.4)
@MikroTik support
Is there anyway an associative array can be defined by a user (and then accessed using the above, or different, syntax), or is this currently just internally supported? If just internally at the moment - any plans to add it for users in the (near) future?
mrz
Tue Sep 17, 2013 3:08 pm
ros code
:pick $assoc "a"
ros code
:pick $assoc 0
ros code
[admin@x86] > :global aaa {a=1;b=2;c=3}
[admin@x86] > :put ($aaa->"a")
1
[admin@x86] > :put ($aaa->"b")
2
boen_robot
Tue Sep 17, 2013 3:12 pm
Well... THAT seems to work. And I also tried time and Boolean values, and they work too.
In that case, it seems the problem is limited just to string values - they are always empty.
And also, the new "->" is not yet documented.
mrz
Tue Sep 17, 2013 3:16 pm
Could you post some example with strings that doesn't work?
boen_robot
Tue Sep 17, 2013 3:20 pm
Just did in the last post:
:put [($assoc->"a")]
If you replace
"test1"
with a number, a time or Boolean value, it works as expected, but this doesn't, and unquoting the string doesn't help either, i.e.
:local assoc {"a"=test1}
also outputs an empty line.
All of these are from within a script in "/system script" that is then "run"-ed from a Winbox terminal window, with the router being an x86 machine (in case that's relevant too).
mrz
Tue Sep 17, 2013 3:33 pm
Thanks it is a bug, creates array of both elements (see :environment print)
We will fix this.
jonmansey
Mon Oct 07, 2013 11:54 pm
How do you set just one element of such a hash?
:global assoc {a=1;b=2;c=3};
:put ($assoc->"a")
1
:put ($assoc->"b")
2
env pr
assoc={a=1; b=2; c=3}
now i want to change the value of b
:set assoc {b=5}
:put ($assoc->"b")
5
but now when I look at the other rows, they are gone. the set has wiped out the other elements.
:put ($assoc->"a")
<blank>
env pr
assoc=
whats the correct set syntax to change only one element of a hash? Thanks
efaden
Thu Nov 14, 2013 6:34 pm
:put ($assoc->"a")
1
:put ($assoc->"b")
2
env pr
:set assoc {b=5}
:put ($assoc->"b")
5
:put ($assoc->"a")
<blank>
env pr
assoc=
Was there ever an answer to this? How do you set a single element in an array? or an associative array?
mrz
Fri Nov 15, 2013 1:24 pm
set overwrites value of variable, so in example you are setting array with one element
:set assoc {b=5}
Currently there is no command to change single element in array.
efaden
Fri Nov 15, 2013 2:26 pm
:set assoc {b=5}
Ugh... ok. Helping someone out with a project and the basically non-existent data structures and lack of atomic operations are a problem. I can't use pick and set since if the thread gets interrupted I will be hosed... some sort of semaphore/mutex or something along with push/pop and actual linked lists would be really useful.
mrz
Fri Nov 15, 2013 3:24 pm
We are planning to add commands to change individual array elements. Most likely in v6.7 you will have this feature.
efaden
Fri Nov 15, 2013 4:14 pm
What about atomic operations?... right now if I have multiple threads attempting to access a single list (e.g. utilizing Traffic Monitors etc)... can I be guaranteed that the push/pop operations will not loose entries?
-Eric
boen_robot
Fri Nov 15, 2013 5:21 pm
Personally, I'd prefer named locks instead of some sort of atomic flavored operations.
e.g.
ros code
:lock "nameOfMyLock" do={
# Stuff that must be atomic in relation to "nameOfMyLock".
# i.e. any other code featuring a ":lock" with "nameOfMyLock" will block at that point until THIS section is exited.
    :set "globalVariableCounter" ($globalVariableCounter + 1)
Ideally, there should also be an option for shared locks and a timeout... but most scripts would be fine even with just exclusive indefinite locks.
mrz
Tue Feb 04, 2014 4:33 pm
Now setting value to single array element also works
ros code
[admin@MikroTik] > :global rr { "apple"=12345; "peach"="abe" }
[admin@MikroTik] > :set ($rr->"apple") "lala"
[admin@MikroTik] > :environment print
rr={apple="lala"; peach="abe"}
efaden
Tue Feb 04, 2014 4:43 pm
ros code
How about some sort of mutex/lock/semaphore?
lukkes
Tue Mar 04, 2014 5:42 am
hi, is there a way to assign values to a variable array in ros 5.21 ? just ike this
{a=1;b=3}
thanks;
If you found this post useful don't forget about the karma viewtopic.php?f=1&t=41148
Feed Your FAITH Then Your Doubts Will Starve To Death...!!!
mrz
Tue Mar 04, 2014 1:58 pm
No it doesn't work in v5.x
mfrater
Wed Apr 02, 2014 7:40 am
Can I create an associative array as a global variable without defining the how many elements there will be in the array?
I can't create an array with zero elements, but if I define one or two, I appear to be able to add more that are not defined. But I also appear to have a NULL { } entry at the beginning of the array too.
[admin@seaview2] > :global a {}
syntax error (line 1 column 13)
[admin@seaview2] > :global a {x,y}
[admin@seaview2] > :environment print
a={{}}
[admin@seaview2] > :set ($a->"y") 2
[admin@seaview2] > :set ($a->"x") 5
[admin@seaview2] > :set ($a->"z") 6
a={{}; x=5; y=2; z=6}
[admin@seaview2] >
mrz
Wed Apr 02, 2014 11:18 am
ros code
:global myArray ;
:set $myArray {a=1}
:set ($myArray->"b") 2
:environment print
myArray={a=1; b=2}
mfrater
Thu Apr 03, 2014 1:09 am
Thanks. That works!
If I :set $myArray {a=1} everytime my script runs, it will wipe all entries. I tried this, but it doesn't work.
# script 3
:global myArray;
# Initialise associative array with one key/value pair. Don't initialise it if array contains data, as it will wipe all other entries.
:if ($myArray="") do={
    :set $myArray {a=1}
    :put "myArray initialised";
   } else {
    :put "myArray NOT initialised";
:put [/environment print]
Output:
> /system script run script3
myArray=[:nothing]
mfrater
Thu Apr 03, 2014 1:42 am
ok.
This works.
:if ( [:len $myArray] =0 ) do={
jeroenp
Thu Oct 13, 2016 9:32 am
Yes you can; I asked this a while ago myself at http://forum.mikrotik.com/viewtopic.php ... 96#p549154
## set empty associative array: http://forum.mikrotik.com/viewtopic.php?p=418796#p549154
:local attackCounts ({});
Then use it like this:
    :local attackCount ($attackCounts->$attackIp);
    :local attackCountType [:typeof $attackCount];
    :if ($attackCountType = "num") do={
      :set $attackCount ($attackCount+1);
    } else={
      :set $attackCount 1;
    :set ($attackCounts->$attackIp) ($attackCount);
--jeroen
Users browsing this forum: No registered users and 11 guests
